bypass the cache!
Dear Colleagues, how can i redirect traffic destined for example.com to bypass the cache server?
Regards,
Create a rule for in the “Direct” section of the web proxy.
/ip proxy direct
add dst-host=www.example.com src-address=0.0.0.0/0
thank for the reply,
I’m not using the ‘‘proxy’’ in the mikrotik, instead I’m using thundercache..
is there another solution we can make?
Is Thundercache good and much does it cost to setup
You will need to explain your current setup for us to be able to answer that question.
Thunder cache is gr8..
this is their website: http://www.bmsoftware.org/index.php/en/
