as3
March 5, 2017, 8:17pm
1
I have my MikroTik hEX connected to PureVPN according to these instructions: https://support.purevpn.com/mikrotik-sstp
I have a Roku behind the hEX router, and the Roku connects to most services correctly, but fails to connect to Netflix. Netflix knows that I am connected to a VPN and it blocks me.
I would like to have the Roku traffic bypass the VPN connection and go directly to my ISP instead. I have assigned a static IP address to the Roku, but I cannot figure out how to make the Roku traffic bypass to VPN connection.
Any help is strongly appreciated.
Hi.
I think Netflix blocks almost all VPN service.
You can try using strongdns service,
normis
March 6, 2017, 10:26am
3
Gustavo, as I understand, he does not want to use VPN for Netflix, in fact, only for all other traffic. Right?
as3
March 6, 2017, 1:31pm
4
normis:
That’s correct. I want to use VPN for non-Netflix traffic.
normis
March 6, 2017, 1:36pm
5
step 13 in these instructions says that ALL traffic (0.0.0.0 destinations) will be routed through the tunnel.
Basically you need another such rule, where traffic to Netflix goes directly through the ISP gateway. You have to find out all the netflix addresses.
I have also an idea. You could separate Roku mediaplayer from your local network and route it directly via your ISP gateway; something like :
let suppose you have ether5 port free; remove it from current bridge, if you have one defined, or ether2 (master ) by setting master-port: none
assign to ether5 different ip address class ( Ex.: 172.16.1.1/24 )
define static ip address on Roku from ether5 network range
NAT: masquerade ether5 network range to ISP WAN interface
Mangle: mark-packet, mark-routing in chain prerouting and mark-connection in chain output ( out-interface would be your isp wan interface) for ether5 network range
add routing with dest-address: ether5 network range, gateway: isp wan interface and routing mark from 5.
I do not have any spare RB to test it so i am not sure if it will work for you.
Hope it helps.
kind regards,
The magic is in the MANGLE, if you place a prerouting rule for the device prior to the prerouting rule for the PureVPN, then uncheck the box for passthrough on your new rule, it will not pick up the Routing Mark which the VPN Masquerade is binding on. Without that mark, it will take the default route out, make sure you have a masquerade set up for that device.
Here is the config for bypassing netflix on VPN. It includes all Netflix + Amazon CDN aggregated prefixed worldwide (326 summarized routes instead of ~1.2K routes). Don’t forget to add default route through VPN too.
Tested and working 100%, netflix bypasses VPN by CIDR matching in the route table. It should work anywhere in the world.
The list is made by me using amazon self-provided provided subnets ( https://ip-ranges.amazonaws.com/ip-ranges.json ) and netflix ipv4 prefixes announced over BGP worldwide.
It doesn’t affect throughput that much if fasttrack is enabled, I still get full gigabit routing speed on my ISP. The 311 and 15 in the comments are the number of routes for each destination, so the list is 326 routes long.
No mangling and routing-mark needed if you use VPN for all devices in your LAN.
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.32.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.35.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.52.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.56.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.112.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.124.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.208.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.228.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.232.0.0/13 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.248.0.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=13.250.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.130.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.136.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.144.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.179.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.182.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.184.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.188.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.191.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.194.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.196.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.200.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.204.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.208.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.224.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.228.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.231.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.232.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.236.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=18.253.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=23.20.0.0/14 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=23.246.0.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=27.0.0.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=34.192.0.0/10 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.153.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.154.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.156.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.160.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.176.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.180.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=35.182.0.0/15 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=37.77.184.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=43.250.192.0/23 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=45.57.0.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=46.51.128.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=46.51.192.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=46.51.216.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=46.51.224.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=46.137.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=50.16.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=50.112.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.0.0.0/11 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.32.0.0/13 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.40.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.44.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.0.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.128.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.164.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.172.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.176.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.184.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.192.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.208.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.220.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.46.224.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.47.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.48.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.64.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.80.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.82.0.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.82.176.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.82.187.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.82.188.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.82.192.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.83.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.84.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.88.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.0.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.32.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.39.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.40.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.48.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.64.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.80.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.88.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.92.248.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.0.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.4.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.8.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.16.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.17.16/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.18.178/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.19.236/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.20.16/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.21.14/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.34.56/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.37.222/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.48.22/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.51.28/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.93.249.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.0.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.16.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.19.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.20.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.22.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.24.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.28.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.32.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.64.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.68.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.72.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.80.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.96.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.192.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.196.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.198.0/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.198.128/27 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.199.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.200.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.204.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.208.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.224.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.240.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.248.0/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.248.128/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.248.192/27 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.248.224/28 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.249.0/27 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.249.32/28 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.249.64/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.94.252.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.0.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.16.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.24.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.28.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.30.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.34.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.36.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.40.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.48.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.56.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.64.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.128.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.136.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.138.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.142.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.144.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.148.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.150.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.154.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.156.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.163.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.164.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.168.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.192.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.212.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.225.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.227.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.240.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.248.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.252.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.254.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.255.0/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.95.255.128/27 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.160.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.192.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.205.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.206.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.208.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.224.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.240.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.119.252.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.192.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.193.0/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.193.128/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.194.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.195.0/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.196.192/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.208.64/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.208.128/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.209.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.210.64/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.210.128/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.211.0/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.224.64/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.224.128/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.225.64/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.144.225.128/26 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.192.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.208.0.0/13 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.216.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.218.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.219.0.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.219.32.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.219.56.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.219.64.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.219.96.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.220.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=52.222.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.64.0.0/11 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.144.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.160.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.176.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.182.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.184.0.0/13 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.192.0.0/12 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.208.0.0/13 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.216.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.220.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.222.0.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.222.32.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.222.48.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.222.57.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.222.58.0/28 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.222.128.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.223.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.224.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.228.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.230.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.0.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.128.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.192.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.224.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.240.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.248.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.231.252.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.232.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.236.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.238.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.0.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.1.0/27 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.1.48/28 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.1.64/28 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.2.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.4.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.8.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.16.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.32.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.48.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.96.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.98.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.100.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.104.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.106.252/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.107.252/31 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.108.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.116.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.120.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.128.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.239.192.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.128.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.192.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.200.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.202.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.204.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.208.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.225.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.226.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.228.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.232.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.244.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.240.248.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.241.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.242.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.244.0.0/14 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=54.248.0.0/13 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=64.120.128.0/17 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=66.197.128.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=67.202.0.0/18 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=69.53.224.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=70.132.0.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=72.21.192.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=72.44.32.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=75.101.128.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=79.125.0.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=87.238.80.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=96.127.0.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=103.4.8.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=103.8.172.0/22 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=103.87.204.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=103.246.148.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=107.20.0.0/14 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=108.175.32.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=122.248.192.0/18 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=143.204.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=172.96.97.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=172.96.98.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=174.129.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=175.41.128.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=176.32.64.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=176.32.96.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=176.32.112.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=176.32.120.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=176.32.125.0/25 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=176.34.0.0/16 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=177.71.128.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=177.72.240.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=178.236.0.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=184.72.0.0/15 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=184.169.128.0/17 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=185.2.220.0/22 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=185.9.188.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=185.48.120.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=185.143.16.0/24 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=192.173.64.0/18 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=198.38.96.0/19 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=198.45.48.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=203.83.220.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=204.236.128.0/17 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=204.246.160.0/21 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=204.246.168.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=204.246.174.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=204.246.176.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.192.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.224.0/20 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.240.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.244.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.247.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.248.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.252.0/23 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=205.251.254.0/24 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=207.45.72.0/22 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=207.171.160.0/19 gateway=YOUR_WAN
add comment=NETFLIX-NOVPN15 distance=1 dst-address=208.75.76.0/24 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=216.137.32.0/19 gateway=YOUR_WAN
add comment=AMAZON-NOVPN311 distance=1 dst-address=216.182.224.0/20 gateway=YOUR_WAN
Hey!
And what if i have PPPoE server on my mkt… how to do it then? My PPPoE is on DHCP 172.16.2.x and Lan 10.10.1.x
if you could help me i would really appriciete Thanks
Netflix constantly upgrades its VPN detection system. I was using Express VPN to unblock American Netflix and it was working fine at first. However, it suddenly stopped working. Just a month back I have switched to NordVPN and it is working as of now. I used this NordVPN Netflix guide to help me through.
rea1ity
October 15, 2018, 8:50am
12
It need update except Netflix service ip address.
Today I checked Netflix have more IPs.
How can I collect the Netflix service IPs using Mikrotik?
This is really uncomfortable to watch Netflix with using VPN.
Easy, in the mangle pre-routing rule exclude the ip of the Roku as source address. Or create an address list and exclude it in the mangle pre-routing rule
As Netflix block many VPNs that’s why its very difficult to choose which VPN will really work for Netflix from anywhere. Now don’t worry about it I found the comprehensive guide about the best VPN for Netflix. After following the guidelines I started using ExpressVPN now and I can use Netflix anywhere without having any issues. If you want to know more VPN services that work for Netflix here is the source for it: https://www.reviewsdir.com/netflix-vpn/
Thanks for the netflix and amazon addresses, worked great,
if you would prefer to not change the routing table you can add these addresses to an address list and then exclude the address list on the mangle rule you use to send your traffic over the vpn
you can paste my code below if you find it helpful
/ip firewall address-list
add address=13.32.0.0/15 list=“VPN Aware Providers”
add address=13.35.0.0/16 list=“VPN Aware Providers”
add address=13.52.0.0/14 list=“VPN Aware Providers”
add address=13.56.0.0/14 list=“VPN Aware Providers”
add address=13.112.0.0/14 list=“VPN Aware Providers”
add address=13.124.0.0/14 list=“VPN Aware Providers”
add address=13.208.0.0/14 list=“VPN Aware Providers”
add address=13.228.0.0/14 list=“VPN Aware Providers”
add address=13.232.0.0/13 list=“VPN Aware Providers”
add address=13.248.0.0/19 list=“VPN Aware Providers”
add address=13.250.0.0/15 list=“VPN Aware Providers”
add address=18.130.0.0/16 list=“VPN Aware Providers”
add address=18.136.0.0/16 list=“VPN Aware Providers”
add address=18.144.0.0/15 list=“VPN Aware Providers”
add address=18.179.0.0/16 list=“VPN Aware Providers”
add address=18.182.0.0/16 list=“VPN Aware Providers”
add address=18.184.0.0/15 list=“VPN Aware Providers”
add address=18.188.0.0/16 list=“VPN Aware Providers”
add address=18.191.0.0/16 list=“VPN Aware Providers”
add address=18.194.0.0/15 list=“VPN Aware Providers”
add address=18.196.0.0/15 list=“VPN Aware Providers”
add address=18.200.0.0/16 list=“VPN Aware Providers”
add address=18.204.0.0/14 list=“VPN Aware Providers”
add address=18.208.0.0/12 list=“VPN Aware Providers”
add address=18.224.0.0/14 list=“VPN Aware Providers”
add address=18.228.0.0/16 list=“VPN Aware Providers”
add address=18.231.0.0/16 list=“VPN Aware Providers”
add address=18.232.0.0/14 list=“VPN Aware Providers”
add address=18.236.0.0/15 list=“VPN Aware Providers”
add address=18.253.0.0/16 list=“VPN Aware Providers”
add address=23.20.0.0/14 list=“VPN Aware Providers”
add address=23.246.0.0/18 list=“VPN Aware Providers”
add address=27.0.0.0/22 list=“VPN Aware Providers”
add address=34.192.0.0/10 list=“VPN Aware Providers”
add address=35.153.0.0/16 list=“VPN Aware Providers”
add address=35.154.0.0/15 list=“VPN Aware Providers”
add address=35.156.0.0/14 list=“VPN Aware Providers”
add address=35.160.0.0/12 list=“VPN Aware Providers”
add address=35.176.0.0/14 list=“VPN Aware Providers”
add address=35.180.0.0/16 list=“VPN Aware Providers”
add address=35.182.0.0/15 list=“VPN Aware Providers”
add address=37.77.184.0/21 list=“VPN Aware Providers”
add address=43.250.192.0/23 list=“VPN Aware Providers”
add address=45.57.0.0/17 list=“VPN Aware Providers”
add address=46.51.128.0/18 list=“VPN Aware Providers”
add address=46.51.192.0/20 list=“VPN Aware Providers”
add address=46.51.216.0/21 list=“VPN Aware Providers”
add address=46.51.224.0/19 list=“VPN Aware Providers”
add address=46.137.0.0/16 list=“VPN Aware Providers”
add address=50.16.0.0/14 list=“VPN Aware Providers”
add address=50.112.0.0/16 list=“VPN Aware Providers”
add address=52.0.0.0/11 list=“VPN Aware Providers”
add address=52.32.0.0/13 list=“VPN Aware Providers”
add address=52.40.0.0/14 list=“VPN Aware Providers”
add address=52.44.0.0/15 list=“VPN Aware Providers”
add address=52.46.0.0/17 list=“VPN Aware Providers”
add address=52.46.128.0/19 list=“VPN Aware Providers”
add address=52.46.164.0/23 list=“VPN Aware Providers”
add address=52.46.172.0/22 list=“VPN Aware Providers”
add address=52.46.176.0/21 list=“VPN Aware Providers”
add address=52.46.184.0/22 list=“VPN Aware Providers”
add address=52.46.192.0/20 list=“VPN Aware Providers”
add address=52.46.208.0/21 list=“VPN Aware Providers”
add address=52.46.220.0/22 list=“VPN Aware Providers”
add address=52.46.224.0/20 list=“VPN Aware Providers”
add address=52.47.0.0/16 list=“VPN Aware Providers”
add address=52.48.0.0/12 list=“VPN Aware Providers”
add address=52.64.0.0/12 list=“VPN Aware Providers”
add address=52.80.0.0/15 list=“VPN Aware Providers”
add address=52.82.0.0/17 list=“VPN Aware Providers”
add address=52.82.176.0/21 list=“VPN Aware Providers”
add address=52.82.187.0/24 list=“VPN Aware Providers”
add address=52.82.188.0/22 list=“VPN Aware Providers”
add address=52.82.192.0/18 list=“VPN Aware Providers”
add address=52.83.0.0/16 list=“VPN Aware Providers”
add address=52.84.0.0/14 list=“VPN Aware Providers”
add address=52.88.0.0/14 list=“VPN Aware Providers”
add address=52.92.0.0/19 list=“VPN Aware Providers”
add address=52.92.32.0/22 list=“VPN Aware Providers”
add address=52.92.39.0/24 list=“VPN Aware Providers”
add address=52.92.40.0/21 list=“VPN Aware Providers”
add address=52.92.48.0/20 list=“VPN Aware Providers”
add address=52.92.64.0/20 list=“VPN Aware Providers”
add address=52.92.80.0/21 list=“VPN Aware Providers”
add address=52.92.88.0/22 list=“VPN Aware Providers”
add address=52.92.248.0/21 list=“VPN Aware Providers”
add address=52.93.0.0/22 list=“VPN Aware Providers”
add address=52.93.4.0/23 list=“VPN Aware Providers”
add address=52.93.8.0/22 list=“VPN Aware Providers”
add address=52.93.16.0/24 list=“VPN Aware Providers”
add address=52.93.17.16/31 list=“VPN Aware Providers”
add address=52.93.18.178/31 list=“VPN Aware Providers”
add address=52.93.19.236/31 list=“VPN Aware Providers”
add address=52.93.20.16/31 list=“VPN Aware Providers”
add address=52.93.21.14/31 list=“VPN Aware Providers”
add address=52.93.34.56/31 list=“VPN Aware Providers”
add address=52.93.37.222/31 list=“VPN Aware Providers”
add address=52.93.48.22/31 list=“VPN Aware Providers”
add address=52.93.51.28/31 list=“VPN Aware Providers”
add address=52.93.249.0/24 list=“VPN Aware Providers”
add address=52.94.0.0/20 list=“VPN Aware Providers”
add address=52.94.16.0/23 list=“VPN Aware Providers”
add address=52.94.19.0/24 list=“VPN Aware Providers”
add address=52.94.20.0/24 list=“VPN Aware Providers”
add address=52.94.22.0/23 list=“VPN Aware Providers”
add address=52.94.24.0/22 list=“VPN Aware Providers”
add address=52.94.28.0/23 list=“VPN Aware Providers”
add address=52.94.32.0/19 list=“VPN Aware Providers”
add address=52.94.64.0/22 list=“VPN Aware Providers”
add address=52.94.68.0/23 list=“VPN Aware Providers”
add address=52.94.72.0/21 list=“VPN Aware Providers”
add address=52.94.80.0/20 list=“VPN Aware Providers”
add address=52.94.96.0/19 list=“VPN Aware Providers”
add address=52.94.192.0/22 list=“VPN Aware Providers”
add address=52.94.196.0/23 list=“VPN Aware Providers”
add address=52.94.198.0/25 list=“VPN Aware Providers”
add address=52.94.198.128/27 list=“VPN Aware Providers”
add address=52.94.199.0/24 list=“VPN Aware Providers”
add address=52.94.200.0/24 list=“VPN Aware Providers”
add address=52.94.204.0/22 list=“VPN Aware Providers”
add address=52.94.208.0/20 list=“VPN Aware Providers”
add address=52.94.224.0/20 list=“VPN Aware Providers”
add address=52.94.240.0/21 list=“VPN Aware Providers”
add address=52.94.248.0/25 list=“VPN Aware Providers”
add address=52.94.248.128/26 list=“VPN Aware Providers”
add address=52.94.248.192/27 list=“VPN Aware Providers”
add address=52.94.248.224/28 list=“VPN Aware Providers”
add address=52.94.249.0/27 list=“VPN Aware Providers”
add address=52.94.249.32/28 list=“VPN Aware Providers”
add address=52.94.249.64/26 list=“VPN Aware Providers”
add address=52.94.252.0/22 list=“VPN Aware Providers”
add address=52.95.0.0/20 list=“VPN Aware Providers”
add address=52.95.16.0/21 list=“VPN Aware Providers”
add address=52.95.24.0/22 list=“VPN Aware Providers”
add address=52.95.28.0/24 list=“VPN Aware Providers”
add address=52.95.30.0/23 list=“VPN Aware Providers”
add address=52.95.34.0/23 list=“VPN Aware Providers”
add address=52.95.36.0/22 list=“VPN Aware Providers”
add address=52.95.40.0/24 list=“VPN Aware Providers”
add address=52.95.48.0/22 list=“VPN Aware Providers”
add address=52.95.56.0/21 list=“VPN Aware Providers”
add address=52.95.64.0/18 list=“VPN Aware Providers”
add address=52.95.128.0/21 list=“VPN Aware Providers”
add address=52.95.136.0/23 list=“VPN Aware Providers”
add address=52.95.138.0/24 list=“VPN Aware Providers”
add address=52.95.142.0/23 list=“VPN Aware Providers”
add address=52.95.144.0/22 list=“VPN Aware Providers”
add address=52.95.148.0/23 list=“VPN Aware Providers”
add address=52.95.150.0/24 list=“VPN Aware Providers”
add address=52.95.154.0/23 list=“VPN Aware Providers”
add address=52.95.156.0/22 list=“VPN Aware Providers”
add address=52.95.163.0/24 list=“VPN Aware Providers”
add address=52.95.164.0/22 list=“VPN Aware Providers”
add address=52.95.168.0/22 list=“VPN Aware Providers”
add address=52.95.192.0/20 list=“VPN Aware Providers”
add address=52.95.212.0/22 list=“VPN Aware Providers”
add address=52.95.225.0/24 list=“VPN Aware Providers”
add address=52.95.227.0/24 list=“VPN Aware Providers”
add address=52.95.240.0/21 list=“VPN Aware Providers”
add address=52.95.248.0/22 list=“VPN Aware Providers”
add address=52.95.252.0/23 list=“VPN Aware Providers”
add address=52.95.254.0/24 list=“VPN Aware Providers”
add address=52.95.255.0/25 list=“VPN Aware Providers”
add address=52.95.255.128/27 list=“VPN Aware Providers”
add address=52.119.160.0/19 list=“VPN Aware Providers”
add address=52.119.192.0/21 list=“VPN Aware Providers”
add address=52.119.205.0/24 list=“VPN Aware Providers”
add address=52.119.206.0/23 list=“VPN Aware Providers”
add address=52.119.208.0/20 list=“VPN Aware Providers”
add address=52.119.224.0/20 list=“VPN Aware Providers”
add address=52.119.240.0/21 list=“VPN Aware Providers”
add address=52.119.252.0/22 list=“VPN Aware Providers”
add address=52.144.192.0/24 list=“VPN Aware Providers”
add address=52.144.193.0/25 list=“VPN Aware Providers”
add address=52.144.193.128/26 list=“VPN Aware Providers”
add address=52.144.194.0/24 list=“VPN Aware Providers”
add address=52.144.195.0/26 list=“VPN Aware Providers”
add address=52.144.196.192/26 list=“VPN Aware Providers”
add address=52.144.208.64/26 list=“VPN Aware Providers”
add address=52.144.208.128/25 list=“VPN Aware Providers”
add address=52.144.209.0/24 list=“VPN Aware Providers”
add address=52.144.210.64/26 list=“VPN Aware Providers”
add address=52.144.210.128/25 list=“VPN Aware Providers”
add address=52.144.211.0/26 list=“VPN Aware Providers”
add address=52.144.224.64/26 list=“VPN Aware Providers”
add address=52.144.224.128/26 list=“VPN Aware Providers”
add address=52.144.225.64/26 list=“VPN Aware Providers”
add address=52.144.225.128/26 list=“VPN Aware Providers”
add address=52.192.0.0/12 list=“VPN Aware Providers”
add address=52.208.0.0/13 list=“VPN Aware Providers”
add address=52.216.0.0/15 list=“VPN Aware Providers”
add address=52.218.0.0/16 list=“VPN Aware Providers”
add address=52.219.0.0/19 list=“VPN Aware Providers”
add address=52.219.32.0/20 list=“VPN Aware Providers”
add address=52.219.56.0/21 list=“VPN Aware Providers”
add address=52.219.64.0/19 list=“VPN Aware Providers”
add address=52.219.96.0/20 list=“VPN Aware Providers”
add address=52.220.0.0/15 list=“VPN Aware Providers”
add address=52.222.0.0/16 list=“VPN Aware Providers”
add address=54.64.0.0/11 list=“VPN Aware Providers”
add address=54.144.0.0/12 list=“VPN Aware Providers”
add address=54.160.0.0/12 list=“VPN Aware Providers”
add address=54.176.0.0/14 list=“VPN Aware Providers”
add address=54.182.0.0/15 list=“VPN Aware Providers”
add address=54.184.0.0/13 list=“VPN Aware Providers”
add address=54.192.0.0/12 list=“VPN Aware Providers”
add address=54.208.0.0/13 list=“VPN Aware Providers”
add address=54.216.0.0/14 list=“VPN Aware Providers”
add address=54.220.0.0/15 list=“VPN Aware Providers”
add address=54.222.0.0/19 list=“VPN Aware Providers”
add address=54.222.32.0/21 list=“VPN Aware Providers”
add address=54.222.48.0/22 list=“VPN Aware Providers”
add address=54.222.57.0/24 list=“VPN Aware Providers”
add address=54.222.58.0/28 list=“VPN Aware Providers”
add address=54.222.128.0/17 list=“VPN Aware Providers”
add address=54.223.0.0/16 list=“VPN Aware Providers”
add address=54.224.0.0/14 list=“VPN Aware Providers”
add address=54.228.0.0/15 list=“VPN Aware Providers”
add address=54.230.0.0/16 list=“VPN Aware Providers”
add address=54.231.0.0/17 list=“VPN Aware Providers”
add address=54.231.128.0/18 list=“VPN Aware Providers”
add address=54.231.192.0/20 list=“VPN Aware Providers”
add address=54.231.224.0/20 list=“VPN Aware Providers”
add address=54.231.240.0/21 list=“VPN Aware Providers”
add address=54.231.248.0/22 list=“VPN Aware Providers”
add address=54.231.252.0/23 list=“VPN Aware Providers”
add address=54.232.0.0/14 list=“VPN Aware Providers”
add address=54.236.0.0/15 list=“VPN Aware Providers”
add address=54.238.0.0/16 list=“VPN Aware Providers”
add address=54.239.0.0/24 list=“VPN Aware Providers”
add address=54.239.1.0/27 list=“VPN Aware Providers”
add address=54.239.1.48/28 list=“VPN Aware Providers”
add address=54.239.1.64/28 list=“VPN Aware Providers”
add address=54.239.2.0/23 list=“VPN Aware Providers”
add address=54.239.4.0/22 list=“VPN Aware Providers”
add address=54.239.8.0/21 list=“VPN Aware Providers”
add address=54.239.16.0/20 list=“VPN Aware Providers”
add address=54.239.32.0/21 list=“VPN Aware Providers”
add address=54.239.48.0/20 list=“VPN Aware Providers”
add address=54.239.96.0/24 list=“VPN Aware Providers”
add address=54.239.98.0/23 list=“VPN Aware Providers”
add address=54.239.100.0/23 list=“VPN Aware Providers”
add address=54.239.104.0/23 list=“VPN Aware Providers”
add address=54.239.106.252/31 list=“VPN Aware Providers”
add address=54.239.107.252/31 list=“VPN Aware Providers”
add address=54.239.108.0/22 list=“VPN Aware Providers”
add address=54.239.116.0/22 list=“VPN Aware Providers”
add address=54.239.120.0/21 list=“VPN Aware Providers”
add address=54.239.128.0/18 list=“VPN Aware Providers”
add address=54.239.192.0/19 list=“VPN Aware Providers”
add address=54.240.128.0/18 list=“VPN Aware Providers”
add address=54.240.192.0/21 list=“VPN Aware Providers”
add address=54.240.200.0/24 list=“VPN Aware Providers”
add address=54.240.202.0/23 list=“VPN Aware Providers”
add address=54.240.204.0/22 list=“VPN Aware Providers”
add address=54.240.208.0/20 list=“VPN Aware Providers”
add address=54.240.225.0/24 list=“VPN Aware Providers”
add address=54.240.226.0/23 list=“VPN Aware Providers”
add address=54.240.228.0/22 list=“VPN Aware Providers”
add address=54.240.232.0/22 list=“VPN Aware Providers”
add address=54.240.244.0/22 list=“VPN Aware Providers”
add address=54.240.248.0/21 list=“VPN Aware Providers”
add address=54.241.0.0/16 list=“VPN Aware Providers”
add address=54.242.0.0/15 list=“VPN Aware Providers”
add address=54.244.0.0/14 list=“VPN Aware Providers”
add address=54.248.0.0/13 list=“VPN Aware Providers”
add address=64.120.128.0/17 list=“VPN Aware Providers”
add address=66.197.128.0/17 list=“VPN Aware Providers”
add address=67.202.0.0/18 list=“VPN Aware Providers”
add address=69.53.224.0/19 list=“VPN Aware Providers”
add address=70.132.0.0/18 list=“VPN Aware Providers”
add address=72.21.192.0/19 list=“VPN Aware Providers”
add address=72.44.32.0/19 list=“VPN Aware Providers”
add address=75.101.128.0/17 list=“VPN Aware Providers”
add address=79.125.0.0/17 list=“VPN Aware Providers”
add address=87.238.80.0/21 list=“VPN Aware Providers”
add address=96.127.0.0/17 list=“VPN Aware Providers”
add address=103.4.8.0/21 list=“VPN Aware Providers”
add address=103.8.172.0/22 list=“VPN Aware Providers”
add address=103.87.204.0/22 list=“VPN Aware Providers”
add address=103.246.148.0/22 list=“VPN Aware Providers”
add address=107.20.0.0/14 list=“VPN Aware Providers”
add address=108.175.32.0/20 list=“VPN Aware Providers”
add address=122.248.192.0/18 list=“VPN Aware Providers”
add address=143.204.0.0/16 list=“VPN Aware Providers”
add address=172.96.97.0/24 list=“VPN Aware Providers”
add address=172.96.98.0/24 list=“VPN Aware Providers”
add address=174.129.0.0/16 list=“VPN Aware Providers”
add address=175.41.128.0/17 list=“VPN Aware Providers”
add address=176.32.64.0/19 list=“VPN Aware Providers”
add address=176.32.96.0/20 list=“VPN Aware Providers”
add address=176.32.112.0/21 list=“VPN Aware Providers”
add address=176.32.120.0/22 list=“VPN Aware Providers”
add address=176.32.125.0/25 list=“VPN Aware Providers”
add address=176.34.0.0/16 list=“VPN Aware Providers”
add address=177.71.128.0/17 list=“VPN Aware Providers”
add address=177.72.240.0/21 list=“VPN Aware Providers”
add address=178.236.0.0/20 list=“VPN Aware Providers”
add address=184.72.0.0/15 list=“VPN Aware Providers”
add address=184.169.128.0/17 list=“VPN Aware Providers”
add address=185.2.220.0/22 list=“VPN Aware Providers”
add address=185.9.188.0/22 list=“VPN Aware Providers”
add address=185.48.120.0/22 list=“VPN Aware Providers”
add address=185.143.16.0/24 list=“VPN Aware Providers”
add address=192.173.64.0/18 list=“VPN Aware Providers”
add address=198.38.96.0/19 list=“VPN Aware Providers”
add address=198.45.48.0/20 list=“VPN Aware Providers”
add address=203.83.220.0/22 list=“VPN Aware Providers”
add address=204.236.128.0/17 list=“VPN Aware Providers”
add address=204.246.160.0/21 list=“VPN Aware Providers”
add address=204.246.168.0/22 list=“VPN Aware Providers”
add address=204.246.174.0/23 list=“VPN Aware Providers”
add address=204.246.176.0/20 list=“VPN Aware Providers”
add address=205.251.192.0/19 list=“VPN Aware Providers”
add address=205.251.224.0/20 list=“VPN Aware Providers”
add address=205.251.240.0/22 list=“VPN Aware Providers”
add address=205.251.244.0/23 list=“VPN Aware Providers”
add address=205.251.247.0/24 list=“VPN Aware Providers”
add address=205.251.248.0/22 list=“VPN Aware Providers”
add address=205.251.252.0/23 list=“VPN Aware Providers”
add address=205.251.254.0/24 list=“VPN Aware Providers”
add address=207.45.72.0/22 list=“VPN Aware Providers”
add address=207.171.160.0/19 list=“VPN Aware Providers”
add address=208.75.76.0/24 list=“VPN Aware Providers”
add address=216.137.32.0/19 list=“VPN Aware Providers”
add address=216.182.224.0/20 list=“VPN Aware Providers”
[quote=tonykakkar post_id=711842 time=1548742796 user_id=129040]
Use ExpressVPN for Netflix. It work like charm for you as it does for me.
[/quote]
My NordVPN subscription expiring this month I heard a lot about ExpressVPN specially for netflix. I was searching it and find many positive feedback. Interested to go with it if they have any deal. Price are bit high.
hi, i am not so familiar with the scripting and marking…
can you post you mangle rule?
i have generated an amazon addresslist manually - i looked which servers appears when starting prime video and added this domains to the list…- dont know if its workling…
i have a rb connected via ether1 to my wan-router (ip 192.168.0.1) and ether 2-10 is a client bridge with the ip 192.168.1.0/24 and on all my TV’s which i want to have connected via vpn for iptv i have configured the ip manually with the rb ip 192.168.1.1 as gateway and dns.. its working but i cannot fix out the mangle rule which is necessary to pass all traffic directly via my wan router and not by vpn which is going to servers of the addresslist=“amazon”.
hope for help here.
kind regards,
olly
