Bypass Webfig Splash
Is there a way in ROS 6 to bypass the first splash screen of webfig and just go to the plain login page with no logos or links to graphs, telnet, etc as the default. When logging in we just want two fields on the page…userid and password, nothing else. Can this be done using skin design? if so how
unfortunately not possible :frowning: .
partial solution:
Thanks for the suggestion. I suppose the best I can do is follow your suggestion and then create a skin that limits the admin account to do minimum viewing of status items only.
