Bytes o bits - Traffic total mikrotik
why mikrotik shows the total traffic in bytes?
in the traffic tab of the Ethernet interface 1, the total tx / rx bytes. It means that the brand is 60Gbytes is equal to 480 gbits?
the total actual traffic measured in bits would be that? 480Gbits?
Regards.
What is the question exactly?
Traffic is measured in Bytes.
Bandwidth is measured in Bits.
You never say that you downloaded a file of 450Gbit
Nor you say you have an uplink of 50Mbyte/s.
