c# api create hotspot user command
hi,
What is the c# api command to create the hotspot user?
Same as with any other client:
/ip/hotspot/user/add
=name=username
=password=password
=profile=profile1
The exact C# code would depend on which C# client we’re talking about.
hi boen_robot,
Mikrotik RB1100AHx2 1U Router Firewall
RouterOS v5.23
WS 2010
c# api class = http://wiki.mikrotik.com/wiki/API_in_C_Sharp
code =
private void createuserBtn_Click(object sender, EventArgs e)
MK mikrotik = new MK(“x.x.x.197”);
if (!mikrotik.Login(“admin”, “123”))
MessageBox.Show(“no connect”);
mikrotik.Close();
return;
MessageBox.Show(“connect”);
mikrotik.Send(“/ip/hotspot/user/add”);
mikrotik.Send(“=name=999”);
mikrotik.Send(“=password=999”);
mikrotik.Send(“=profile=profile1”);
//MessageBox.Show(“create user”);
mikrotik.Close();
result =
connect ok,
create user no,
disconnect ok.
? = Why not create a user… :slight_smile:
Add “false” as a second argument to each method, to ensure all API words are part of the same API sentence.
i.e.
MK mikrotik = new MK("x.x.x.197");
 if (!mikrotik.Login("admin", "123"))
 MessageBox.Show("no connect");
 mikrotik.Close();
 return;
 MessageBox.Show("connect");
 mikrotik.Send("/ip/hotspot/user/add", false);
 mikrotik.Send("=name=999", false);
 mikrotik.Send("=password=999", false);
 mikrotik.Send("=profile=profile1");
 //MessageBox.Show("create user");
 mikrotik.Close();
I tried but it does not …
:frowning:
Perhaps you need to explicitly do a Read() too, even if you’re not going to use the results, e.g.
mikrotik.Read();
hi,
not create user.
:frowning:
Looking at the source, it seems this client has a big bug in it… the “false” thing doesn’t really work - it’s ignored. More importantly though, it always finishes the API sentence. But not all is lost. The version without a second argument doesn’t finish the API sentence, oddly enough.
So, in combination with the Read() thing, you should be able to do it with:
 mikrotik.Close();
 return;
 mikrotik.Send("/ip/hotspot/user/add");
 mikrotik.Send("=name=999");
 mikrotik.Send("=password=999");
 mikrotik.Send("=profile=profile1", true);
 mikrotik.Read();
 mikrotik.Close();
If even that doesn’t work, I’d highly advise you to use the other C# client - the one at the bottom of the API spec.
hi,
thanks.
not with api, I’m trying to ssh in c#
now hotspot user’s balance can view from client pc
http://forum.mikrotik.com/t/now-hotspot-user-can-see-balance-data-from-status-page/65363/1
I have a C# application where I need to update a usermanager user
I use this code
  		MikrotikApi.Send("/tool/user-manager/user/set");
                MikrotikApi.Send("=name=" + username);
                MikrotikApi.Send("=first-name=" + firstName);
                MikrotikApi.Send("=comment=" + comment);
                MikrotikApi.Send("=email=" + email);
                MikrotikApi.Send("=password=" + password);
                MikrotikApi.Send("=customer=admin", true);
And the code is executed with no error.
Yet nothing gets updated . WHY ??? what did I forget here?
Use the argument “numbers” to target items. Everything else is the new value you want for that user (e.g. if you want to rename a user, you’ll want “numbers” with the current username, and “name” with the new username).
The “numbers” argument I think accepts the username, but if it doesn’t, you’ll need to use the “print” command with a query, to get the user’s ID.
I did it already thanks for the quick reply :smiley:
Goodnight.
I have a question, I am trying to add users through the hotspot what happens is that in this code the winbox does not receive the password, only the created user is displayed, I thought it was the false but the same error still appears.
Thank you.
This is the code
class Program
static void Main (string args)
MK mikrotik = new MK (“10.10.0.254”);
if (! mikrotik.Login (“itamar”, “12345678”))
Console.WriteLine (“The account could not be entered”);
Console.ReadKey ();
mikrotik.Close ();
return;
//mikrotik.Send(“/system/identity/getall “);
//mikrotik.Send(”.tag=sss “, true);
mikrotik.Send (”/ ip / hotspot / user / add”);
mikrotik.Send (“= name = user1”, false);
mikrotik.Send (“= password = new2”, false);
mikrotik.Send (“= profile = profile1”, true);
Console.WriteLine (“created user”);
foreach (string h in mikrotik.Read ())
Console.WriteLine (h);
Console.ReadKey ();
can we add a new user with time limits?
Good morning, I’m with this error, someone has a solution.
thank you
