C# API output in separate lines
Im using C# and API code from http://wiki.mikrotik.com/wiki/API_command_notes.
How do I get response in some more readable form than everything in one line.
For example for this commands:
mikrotik.Send("/interface/monitor-traffic");
mikrotik.Send("=interface=ether1");
mikrotik.Send("=once=", true);
…I want something like this:
!re
=rx-packets-per-second=4
=rx-drops-per-second=0
=rx-errors-per-second=0
=rx-bits-per-second=8531
=tx-packets-per-second=3
=tx-drops-per-second=0
=tx-errors-per-second=0
=tx-bits-per-second=11266
Please give me some help on this.
In C#, that is “Split”. Google “C# Split” for examples.
Here is a simple one
http://dotnetperls.com/string-split
I had the same problem… Try this :slight_smile:
   class MK
        Stream connection;
        TcpClient con;
        public MK(string ip)
            con = new TcpClient();
            con.Connect(ip, 8728);
            connection = (Stream)con.GetStream();
        public void Close()
            connection.Close();
            con.Close();
        public bool Login(string username, string password)
            Send("/login", true);
            string hash = Read()[1].Substring(5,32);
            Send("/login");
            Send("=name=" + username);
            Send("=response=00" + EncodePassword(password, hash), true);
            if (Read()[0] == "!done")
                return true;
            else
                return false;
        public void Send(string co)
            byte[] bajty = Encoding.ASCII.GetBytes(co.ToCharArray());
            byte[] velikost = EncodeLength(bajty.Length);
            connection.Write(velikost, 0, velikost.Length);
            connection.Write(bajty, 0, bajty.Length);
        public void Send(string co, bool endsentence)
            connection.WriteByte(0);
        public List<string> Read()
            List<string> returnValue = new List<string>();
            string o = "", p = "";
            byte[] tmp = new byte[4];
            long count;
            while (true)
                if (p != "")
                    returnValue.Add(p);
                    p = "";
                tmp[3] = (byte)connection.ReadByte();
                //if(tmp[3] == 220) tmp[3] = (byte)connection.ReadByte(); it sometimes happend to me that
                //mikrotik send 220 as some kind of "bonus" between words, this fixed things, not sure about it though
                if (tmp[3] == 0)
                    if (o.Substring(0, 5) == "!done")
                        break;
                    else
                        o = "";
                        continue;
                else
                    if (tmp[3] < 0x80)
                        count = tmp[3];
                    else
                        if (tmp[3] < 0xC0)
                            int tmpi = BitConverter.ToInt32(new byte[] { (byte)connection.ReadByte(), tmp[3], 0, 0 }, 0);
                            count = tmpi ^ 0x8000;
                        else
                            if (tmp[3] < 0xE0)
                                tmp[2] = (byte)connection.ReadByte();
                                int tmpi = BitConverter.ToInt32(new byte[] { (byte)connection.ReadByte(), tmp[2], tmp[3], 0 }, 0);
                                count = tmpi ^ 0xC00000;
                            else
                                if (tmp[3] < 0xF0)
                                    tmp[1] = (byte)connection.ReadByte();
                                    int tmpi = BitConverter.ToInt32(new byte[] { (byte)connection.ReadByte(), tmp[1], tmp[2], tmp[3] }, 0);
                                    count = tmpi ^ 0xE0000000;
                                else
                                    if (tmp[3] == 0xF0)
                                        tmp[0] = (byte)connection.ReadByte();
                                        count = BitConverter.ToInt32(tmp, 0);
                                    else
                                        //Error in packet reception, unknown length
                                        break;
                for (int i = 0; i < count; i++)
                    p += (Char)connection.ReadByte();
                o += p;
            return returnValue;
        byte[] EncodeLength(int delka)
            if (delka < 0x80)
                byte[] tmp = BitConverter.GetBytes(delka);
                return new byte[1] { tmp[0] };
            if (delka < 0x4000)
                byte[] tmp = BitConverter.GetBytes(delka | 0x8000);
                return new byte[2] { tmp[1], tmp[0] };
            if (delka < 0x200000)
                byte[] tmp = BitConverter.GetBytes(delka | 0xC00000);
                return new byte[3] { tmp[2], tmp[1], tmp[0] };
            if (delka < 0x10000000)
                byte[] tmp = BitConverter.GetBytes(delka | 0xE0000000);
                return new byte[4] { tmp[3], tmp[2], tmp[1], tmp[0] };
            else
                return new byte[5] { 0xF0, tmp[3], tmp[2], tmp[1], tmp[0] };
        public string EncodePassword(string Password, string hash)
            byte[] hash_byte = new byte[hash.Length / 2];
            for (int i = 0; i <= hash.Length - 2; i += 2)
                hash_byte[i / 2] = Byte.Parse(hash.Substring(i, 2), System.Globalization.NumberStyles.HexNumber);
            byte[] heslo = new byte[1 + Password.Length + hash_byte.Length];
            heslo[0] = 0;
            Encoding.ASCII.GetBytes(Password.ToCharArray()).CopyTo(heslo, 1);
            hash_byte.CopyTo(heslo, 1 + Password.Length);
            Byte[] hotovo;
            System.Security.Cryptography.MD5 md5;
            md5 = new System.Security.Cryptography.MD5CryptoServiceProvider();
            hotovo = md5.ComputeHash(heslo);
            //Convert encoded bytes back to a 'readable' string
            string navrat = "";
            foreach (byte h in hotovo)
                navrat += h.ToString("x2");
            return navrat;
