I have hardware problems
C52iG-5HaxD2HaxD-TC
After update 7.6 to 7.8
Missing interfaces wlan(Wifi)
I tried different reset methods including via netinstall and it didn’t work
C52iG-5HaxD2HaxD-TC
Did you upgrade manually by single packages? The you forgot wifiwave2.npk package
Normally you should upgrade with “check for updates” button and this won’t happen.
