C53UiG+5HPaxD2HPaxD wireguard performance
I am wondering to purchase C53UiG+5HPaxD2HPaxD IPQ-6010 but I want to check router performance serving wireguard client on it for max possible throughput before SoC reaches bottleneck. Could someone please provide test results ?
Sorry for posting this here, was not able to find information over the web for relatively new device on QC IPQ-6010 SoC
Raw testing between RB5009 and AX3 connection using 2.5Gb-trunk internally at home.
850Mb TCP, on AX3 there was 1 core maxing out.
UDP roughly the same.
Tested again without WG connection as reference, UDP reached almost 2.3Gbps.
No cores maxing out on either end, so the connection itself was bottle-neck there.
