CA isn't required? Match server n client cert not required?
Openvpn, certificates, CA
Hi guru!
Is CA not required in mikrotik openvpn server and mikrotik openvpn client?
In practice found that mikrotik do not match even server and client certificate at all. It’s strange and bad. (or I am wrong?).
Mmmkey.
Let’s begin.
In this page
OpenVPN#Server_configuration
we know
“On RouterOS, all you have to do is to upload them via ftp (ca certificate and router certificate and private key) and import them with /certificate import”
We interested in task to login from client to openvpn server by login/password/certificate.
Certificates were created with this help
Manual:Create_Certificates
there are:
openvpnclient1.crt
openvpnclient1.key
openvpnserver.crt
openvpnserver.key
ca.crt
ca.key
#1. Do as book says. (Require client certificate checkbox is set to on).
Imported to mikrotik server:
ca.crt
ca.key
openvpnserver.crt
openvpnserver.key
Imported to mikrotik client:
openvpnclient1.crt
openvpnclient1.key
ca.crt
ca.key
That’s enough. Try connect by login/password and this set of certificates – status connected. Very well.
#2. The same but remove ca.crt, ca.key from mikrotik client openvpn.
Reboot for clean experiment.
server:
ca.crt
ca.key
openvpnserver.crt
openvpnserver.key
client:
openvpnclient1.crt
openvpnclient1.key
It works. Status connected. Strange…
#3. As above but remove ca.crt, ca.key from mikrotik server openvpn.
server:
openvpnserver.crt
openvpnserver.key
client:
openvpnclient1.crt
openvpnclient1.key
#4. Import to mikrotik client openvpn wrong certificates (ca.crt pair for example) and use for client connection
/interface ovpn-client … certificate=CA … name=ovpn-client password=sdkfjh profile=ovpn user=…
server:
openvpnserver.crt
openvpnserver.key
client:
ca.crt
ca.key
#5. As above but use server certificates on both sides:
server:
openvpnserver.crt
openvpnserver.key
client:
openvpnserver.crt
openvpnserver.key
#6. As above but use client certificates on both sides:
server:
openvpnclient1.crt
openvpnclient1.key
client:
openvpnclient1.crt
openvpnclient1.key
WTF&WHY?
added:
month ago i generated certificates and keys for other mikrotik. now try use this old client certificates for mikrotik openvon client. and good news - no connection.
that means mikrotik taking certificates into account. but effect of them is a big question.
Thnx 4 ur time.
