CA on chateau lte12
I’m try to force CA more than 2 bands just to increase speed.
If i connect data with iphone8 to the same bts cellid, i see CA with 3 bands 3+7+20 and speed is 200mbps.
But with mikrotik, using the same cellid bts, i see only 2 bands, the band 3 on primary and 20 on CA, and speed is slow than iphone.
Signal is good, and i see the bts (1 km far)
on lte interface setting, all bands are selected.
How can i force the CA to 3 bands?
OS is 7.1beta2
In LTE you can only select the Primary-Band by Cell-Lock feature, the CA is always from your eNB.
At Quactel EG12 you should have that CA possible and remember that module can disable CA when you not generate a traffic and when you generate traffic then CA can be show again.
Additional do some testing with downloading torrent file with e.g. Ubuntu iso file to confirm or not problems like:
thank you Sib
