is there any update on this, will this applicable to the RBMetal 5SHPn?
Detect Cable Problems
In RouterOS v6rc4 and newer releases there is the ability to detect problems with connected cables. Cable test can detect problems or measure the approximate cable length if the cable is unplugged on the other end and there is therefore, "no-link". RouterOS will tell:
which cable pair is damaged
the distance to the problem
how exactly the cable is broken - short-circuited or open-circuited
This also works if the other end is simply unplugged - in that case, the total cable length will be shown.
This works on SXT-G, SXT Lite, RB711G, RB2011, RB750 series and other devices with the same switch chips, and also the Cloud Core series devices.
