dear all
i have a cache proxy box before the MT box. i want any file in the cache server served to the users in full speed and not limited to the MT speeds given to the users.
10x in advance
dear all
10x in advance
Add this rule to the used ‘queue’ type, if you are using ‘queue simple’ add rules that will set unlimited bandwidth for proxy server (dst-address in ‘queue simple’), queue tree example is given here,
http://wiki.mikrotik.com/wiki/Queue_with_Masquerading_and_Internal_Web-Proxy
hi again
if it is used with the ppoe???
thanks in advance
Hello again
I am using DHCP with arp .
Hi Sergejs
i want to use it for pppoe server , is there any modifications for it ?
10x again
Hi Sergejs
i use only pppoe how can it work for it?
10x and waiting for your reply
It is possible with static queues, not with dynamic from PPPoE or DHCP servers.
