Cache hit DSCP (TOS)
i have a rb433AH and i added a microsd card to it for caching purposes.
i am on satellite internet so its vital i am able to use the cache…
my two questions are:
if i enable: Always from cache will this screw up some times?
also, how do you figure out what the best value for the “Cache hit DSCP” field is?
pls advise.
bump ?
cylent stop posting in other people’s threads. make your own
you don’t have to use DSCP unless there is a specific reason. what exactly do you need to achieve here?
better caching :slight_smile:
you can use DSCP Type of Service markings to tell apart different types of traffic. In some cases it’s used to tell apart HIT and MISS traffic.
By no means it is required in all webproxy setups
