Here I’ll post some templates for Cacti. Each one of them is created for Mikrotik - Ruter OS. To use them you must have Cacti installed. You can get it from http://www.cacti.net .
Next go to Import templates and paste the text in “code” bellow.
CPU Usage
<cacti>
<hash_000005e698bfeed6840d045766635a9bacbbe0>
<name>Mikrotik - CPU Usage</name>
<graph>
<t_title></t_title>
<title>|host_description| - CPU Usage</title>
<t_image_format_id></t_image_format_id>
<image_format_id>1</image_format_id>
<t_height></t_height>
<height>120</height>
<t_width></t_width>
<width>500</width>
<t_auto_scale></t_auto_scale>
<auto_scale>on</auto_scale>
<t_auto_scale_opts></t_auto_scale_opts>
<auto_scale_opts>2</auto_scale_opts>
<t_auto_scale_log></t_auto_scale_log>
<auto_scale_log></auto_scale_log>
<t_auto_scale_rigid></t_auto_scale_rigid>
<auto_scale_rigid>on</auto_scale_rigid>
<t_auto_padding></t_auto_padding>
<auto_padding>on</auto_padding>
<t_export></t_export>
<export>on</export>
<t_upper_limit></t_upper_limit>
<upper_limit>100</upper_limit>
<t_lower_limit></t_lower_limit>
<lower_limit>0</lower_limit>
<t_base_value></t_base_value>
<base_value>1000</base_value>
<t_unit_value></t_unit_value>
<unit_value></unit_value>
<t_unit_exponent_value></t_unit_exponent_value>
<unit_exponent_value></unit_exponent_value>
<t_vertical_label></t_vertical_label>
<vertical_label>percent</vertical_label>
</graph>
<items>
<hash_100005057d15afb7d8a06b90258c7988ee0b71>
<task_item_id>hash_08000548f515755838763a71d68ed3d0fc7175</task_item_id>
<color_id>FF0000</color_id>
<graph_type_id>7</graph_type_id>
<consolidation_function_id>1</consolidation_function_id>
<cdef_id>0</cdef_id>
<value></value>
<gprint_id>hash_060005e9c43831e54eca8069317a2ce8c6f751</gprint_id>
<text_format>CPU Usage</text_format>
<hard_return></hard_return>
<sequence>1</sequence>
</hash_100005057d15afb7d8a06b90258c7988ee0b71>
<hash_1000054b4bebaa5ec20a923a826fd072767e9a>
<color_id>0</color_id>
<graph_type_id>9</graph_type_id>
<consolidation_function_id>4</consolidation_function_id>
<value></value>
<gprint_id>hash_06000519414480d6897c8731c7dc6c5310653e</gprint_id>
<text_format>Current:</text_format>
<sequence>2</sequence>
</hash_1000054b4bebaa5ec20a923a826fd072767e9a>
<hash_100005a49d96e10a3dc74512596d8485763649>
<value></value>
<text_format>Average:</text_format>
<sequence>3</sequence>
</hash_100005a49d96e10a3dc74512596d8485763649>
<hash_100005e7cb030d1036ffac6c675322240a4066>
<consolidation_function_id>3</consolidation_function_id>
<value></value>
<text_format>Maximum:</text_format>
<sequence>4</sequence>
</hash_100005e7cb030d1036ffac6c675322240a4066>
</items>
<inputs>
<hash_0900056e0f7a10eb1457ad6881bb3defc47140>
<name>Data Source [cpu]</name>
<description></description>
<column_name>task_item_id</column_name>
<items>hash_000005057d15afb7d8a06b90258c7988ee0b71|hash_0000054b4bebaa5ec20a923a826fd072767e9a|hash_000005a49d96e10a3dc74512596d8485763649|hash_000005e7cb030d1036ffac6c675322240a4066</items>
</hash_0900056e0f7a10eb1457ad6881bb3defc47140>
</inputs>
</hash_000005e698bfeed6840d045766635a9bacbbe0>
<hash_010005097a276485e6746cb677900ec4062d59>
<name>Mikrotik - SNMP - CPU Load</name>
<ds>
<t_name></t_name>
<name>|host_description| - Mikrotik - SNMP - CPU Load (5 min)</name>
<data_input_id>hash_0300053eb92bb845b9660a7445cf9740726522</data_input_id>
<t_rra_id></t_rra_id>
<t_rrd_step></t_rrd_step>
<rrd_step>300</rrd_step>
<t_active></t_active>
<active>on</active>
<rra_items>hash_150005c21df5178e5c955013591239eb0afd46|hash_1500050d9c0af8b8acdc7807943937b3208e29|hash_1500056fc2d038fb42950138b0ce3e9874cc60|hash_150005e36f3adb9f152adfa5dc50fd2b23337e</rra_items>
</ds>
<items>
<hash_08000548f515755838763a71d68ed3d0fc7175>
<t_data_source_name></t_data_source_name>
<data_source_name>cpu</data_source_name>
<t_rrd_minimum></t_rrd_minimum>
<rrd_minimum>0</rrd_minimum>
<t_rrd_maximum></t_rrd_maximum>
<rrd_maximum>100</rrd_maximum>
<t_data_source_type_id></t_data_source_type_id>
<data_source_type_id>1</data_source_type_id>
<t_rrd_heartbeat></t_rrd_heartbeat>
<rrd_heartbeat>600</rrd_heartbeat>
<t_data_input_field_id></t_data_input_field_id>
<data_input_field_id>0</data_input_field_id>
</hash_08000548f515755838763a71d68ed3d0fc7175>
</items>
<data>
<item_000>
<data_input_field_id>hash_0700054276a5ec6e3fe33995129041b1909762</data_input_field_id>
<t_value></t_value>
<value>.1.3.6.1.2.1.25.3.3.1.2.1</value>
</item_000>
<item_001>
<data_input_field_id>hash_070005012ccb1d3687d3edb29c002ea66e72da</data_input_field_id>
<t_value></t_value>
<value></value>
</item_001>
<item_002>
<data_input_field_id>hash_0700059c55a74bd571b4f00a96fd4b793278c6</data_input_field_id>
<t_value></t_value>
<value></value>
</item_002>
<item_003>
<data_input_field_id>hash_070005ad14ac90641aed388139f6ba86a2e48b</data_input_field_id>
<t_value></t_value>
<value></value>
</item_003>
<item_004>
<data_input_field_id>hash_07000532285d5bf16e56c478f5e83f32cda9ef</data_input_field_id>
<t_value></t_value>
<value></value>
</item_004>
<item_005>
<data_input_field_id>hash_07000592f5906c8dc0f964b41f4253df582c38</data_input_field_id>
<t_value></t_value>
<value></value>
</item_005>
</data>
</hash_010005097a276485e6746cb677900ec4062d59>
<hash_0300053eb92bb845b9660a7445cf9740726522>
<name>Get SNMP Data</name>
<type_id>2</type_id>
<input_string></input_string>
<fields>
<hash_07000592f5906c8dc0f964b41f4253df582c38>
<name>SNMP IP Address</name>
<update_rra></update_rra>
<regexp_match></regexp_match>
<allow_nulls></allow_nulls>
<type_code>hostname</type_code>
<input_output>in</input_output>
<data_name>management_ip</data_name>
</hash_07000592f5906c8dc0f964b41f4253df582c38>
<hash_07000532285d5bf16e56c478f5e83f32cda9ef>
<name>SNMP Community</name>
<type_code>snmp_community</type_code>
<data_name>snmp_community</data_name>
</hash_07000532285d5bf16e56c478f5e83f32cda9ef>
<hash_070005ad14ac90641aed388139f6ba86a2e48b>
<name>SNMP Username</name>
<allow_nulls>on</allow_nulls>
<type_code>snmp_username</type_code>
<data_name>snmp_username</data_name>
</hash_070005ad14ac90641aed388139f6ba86a2e48b>
<hash_0700059c55a74bd571b4f00a96fd4b793278c6>
<name>SNMP Password</name>
<type_code>snmp_password</type_code>
<data_name>snmp_password</data_name>
</hash_0700059c55a74bd571b4f00a96fd4b793278c6>
<hash_070005012ccb1d3687d3edb29c002ea66e72da>
<name>SNMP Version (1, 2, or 3)</name>
<type_code>snmp_version</type_code>
<data_name>snmp_version</data_name>
</hash_070005012ccb1d3687d3edb29c002ea66e72da>
<hash_0700054276a5ec6e3fe33995129041b1909762>
<name>OID</name>
<type_code>snmp_oid</type_code>
<data_name>oid</data_name>
</hash_0700054276a5ec6e3fe33995129041b1909762>
</fields>
</hash_0300053eb92bb845b9660a7445cf9740726522>
<hash_150005c21df5178e5c955013591239eb0afd46>
<name>Daily (5 Minute Average)</name>
<x_files_factor>0.5</x_files_factor>
<steps>1</steps>
<rows>600</rows>
<timespan>86400</timespan>
<cf_items>1|3</cf_items>
</hash_150005c21df5178e5c955013591239eb0afd46>
<hash_1500050d9c0af8b8acdc7807943937b3208e29>
<name>Weekly (30 Minute Average)</name>
<steps>6</steps>
<rows>700</rows>
<timespan>604800</timespan>
</hash_1500050d9c0af8b8acdc7807943937b3208e29>
<hash_1500056fc2d038fb42950138b0ce3e9874cc60>
<name>Monthly (2 Hour Average)</name>
<steps>24</steps>
<rows>775</rows>
<timespan>2678400</timespan>
</hash_1500056fc2d038fb42950138b0ce3e9874cc60>
<hash_150005e36f3adb9f152adfa5dc50fd2b23337e>
<name>Yearly (1 Day Average)</name>
<steps>288</steps>
<rows>797</rows>
<timespan>33053184</timespan>
</hash_150005e36f3adb9f152adfa5dc50fd2b23337e>
<hash_060005e9c43831e54eca8069317a2ce8c6f751>
<name>Normal</name>
<gprint_text>%8.2lf %s</gprint_text>
</hash_060005e9c43831e54eca8069317a2ce8c6f751>
<hash_06000519414480d6897c8731c7dc6c5310653e>
<name>Exact Numbers</name>
<gprint_text>%8.0lf</gprint_text>
</hash_06000519414480d6897c8731c7dc6c5310653e>
</cacti>
