Cake QoS and IP6 setup check
Morning all,
So I recently setup Cake Qos and ip6. But I am super paranode, that I did not optimize correctly. The main reason Cake was implemented was due to my Internet providers messed up route, twice removed. I was able to pull tons more bandwidth then I paid for ------ but it was super unstable. Huge latency issues and tons of dropped packets and what not. Put Cake in place and it seems to smoothed things over really well. Latency is still in the 30-40 range, But stable so???
IP6 Is a total mystery to me. It does not make sense that you grab a block of addresses and the devices pick an address at random. It is working but feels ---- wrong ? or implemented incorrectly.
My biggest concern for cake is that I am limiting local Lan speeds
IP6 my worry is I opened my self to much to the internet. And put my self at risk.
I’m guessing that’s ping time in milliseconds? Is that under load, or with nothing running?
The scale of the address space is outside all human experience. Your brain didn’t evolve with any ability to understand values this big, so it struggles and comes up with misanalogies.
I expect you’re aware that IPv4 has a 32-bit address space, and that IPv6 has a 128-bit address space. A normal initial reaction is to see the latter as 4× bigger, but in fact a 34-bit address is 4× bigger, since every additional bit — that is, binary digit — is a doubling. To go from 32-bits to 128-bits is ninety-six doublings!
If your ISP gives you a /64 subnet, that isn’t half the total IPv6 space, it’s one out of 2⁶⁴ subnets available. If each IPv4 address in existence were assigned one of these subnets as a companion, that would use up 2⁹⁶ IPv6 addresses. To use them all up, every IPv4 address would have to be assigned 2³² of these IPv6 /64 subnets.
That’s only one way for IPv6 addressing to work. You can draw them from a DHCPv6 pool, or assign them statically, or base them on MAC addresses, or…
So don’t put it on the LAN interfaces. You can target a RouterOS queue at any interface you like. Post your configuration and a network diagram if you want someone to vet your configuration.
While NAT does provide a type of firewalling, doing without NAT doesn’t mean you are now without a firewall. RouterOS IPv6 firewall rules still apply, even when your clients have public IPv6 addresses.
Again, post your config if you want reassurance.
yes that is ms / and under load.
Let me know if that works— new to uploading configs.
scrubbed some other stuff that I thought should not be shared — if it is an issue I can go over that – but it should not be needed.
# may/31/2022 12:26:02 by RouterOS 7.2.3
# software id = 56LU-W8EI
# model = RB4011iGS+
# serial number = B8F40B74C8FF
add admin-mac=C4:AD:34:xx:xx:xx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp insert-queue-before=bottom interface=bridge name=\
    defconf
/ipv6 dhcp-server
add address-pool="ip 6 pool 60" interface=bridge name=ipv6
/port
set 0 name=serial0
set 1 name=serial1
/queue tree
add disabled=yes name="Total BW" parent=global
/queue type
add kind=pcq name="PCQ download" pcq-classifier=dst-address pcq-rate=500M
add kind=pcq name="PCQ upload" pcq-classifier=src-address pcq-rate=20M
add kind=fq-codel name="Default-fq codel"
add cake-diffserv=diffserv4 cake-mpu=84 cake-nat=yes cake-overhead=38 \
    cake-overhead-scheme=ethernet cake-rtt=60ms cake-wash=yes kind=cake name=\
    "default cake"
add cake-bandwidth=440.0Mbps cake-mpu=84 cake-nat=yes cake-overhead=38 \
    cake-overhead-scheme=ethernet cake-rtt=70ms kind=cake name=\
    "cake from wan"
add cake-bandwidth=30.0Mbps cake-mpu=84 cake-nat=yes cake-overhead=38 \
    "cake from lan"
add kind=none name=nono
/queue simple
add disabled=yes max-limit=400M/20M name=queue1 queue=\
    "Default-fq codel/Default-fq codel" target=ether1 total-queue=\
    "Default-fq codel"
add comment="upload and download are backwords ---- upload =wan" name=\
    "new test with cake" queue="cake from wan/cake from lan" target=ether1 \
    total-queue="default cake"
/queue tree
add disabled=yes name=download packet-mark=download parent="Total BW" queue=\
    "PCQ download"
add disabled=yes name=upload packet-mark=upload parent="Total BW" queue=\
    "PCQ upload"
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
    identity="x" name=zt1 \
    port=9993
/zerotier interface
add allow-default=no allow-global=no allow-managed=yes disabled=no instance=\
    zt1 name=zerotier1 network=x
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
set loose-tcp-tracking=no
/ipv6 settings
set accept-router-advertisements=yes
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=\
    LAN wan-interface-list=WAN
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.1.246 client-id=1:70:5a:f:42:a3:d2 mac-address=\
    70:5A:0F:42:A3:D2 server=defconf
add address=192.168.1.24 client-id=1:8:0:27:5e:2:33 mac-address=\
    08:00:27:5E:02:33 server=defconf
add address=192.168.1.248 client-id=1:38:18:4c:a4:67:75 mac-address=\
    38:18:4C:A4:67:75 server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.1.0/24 list=lan
add address=192.168.2.0/24 list=lan
add address=224.0.0.0/4 list=multcast
add address=255.255.255.255 list=multcast
add action=accept chain=input dst-address-list=lan src-address-list=lan
add action=accept chain=input dst-address-list=multcast src-address-list=lan
add action=accept chain=forward in-interface-list=LAN src-address-list=lan
add action=accept chain=input in-interface=bridge src-address=0.0.0.0
add action=accept chain=forward comment="dst nated" connection-nat-state=\
    dstnat
    connection-state=invalid
    invalid
add action=accept chain=input connection-nat-state=dstnat
    established,related,untracked
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    in-interface-list=!LAN
add action=accept chain=forward log=yes
add action=accept chain=input log=yes
/ip ssh
set strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1 type=external
add interface=bridge type=internal
/ipv6 address
add address=::1 from-pool="ip 6 pool 60" interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=ether1 pool-name="ip 6 pool 60" \
    pool-prefix-length=60 prefix-hint=::/56 request=address,prefix \
    use-interface-duid=yes use-peer-dns=no
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ipv6 nd
/system clock
set time-zone-name=America/Chicago
/tool bandwidth-server
set authenticate=no enabled=no
/tool graphing interface
add allow-address=192.168.1.0/24 interface=bridge
/tool mac-server
/tool mac-server mac-winbox
