Calculating Bursts
Hello
I’ve redone my Burst Calculator
http://www.ip-pro.pl/kalkulator/burst_simulator
What do you think ?
excelent tool!. Is there source code available ?
M.
I thought it was interesting to see how that early in the transfer, the average utilization can continue to climb even after burst ends and throughput is lower than the running average.
It’s also interesting to see how limiting bursts too much can make a transfer take a LOT longer. From a congestion management point of view, sometimes it’s better to let traffic have a huge burst (if capacity is available) so that the transfer completes and gets out of the way for other things, where if you limit it too much it just lingers, using half your bandwidth for more than 2x longer.
interesting.
@ZeroByte
Can you tell me what should i do for my burst rates in my hotspot?
my download limit is 200K and I wanna set 20 sec for burst time
what is the best burst threshold and burst limit?
Thanks for your feedback. I blag you like this tool.
For collegue post higher, Burst threshold should be lower then max limit.
check link on first post to find out best setting for yourself,
Maybe next week I will add to this tool a results how long would a download will take for such and such files.
The graph already shows this (as long as the full download takes less than 2xburst time parameter).
:smiley:
