Only thing that worries me is that the session radacct table is constantly being updated and does not stop until the client dsconnects.
Let’s say someone has been connected for a week ?
Do you query SQL for 1 day, then query it the next day and subtract the next days total from the 2day totals to get your daily total ?
It seems like that is the long way if you know what I mean
Isn’t there some sort of script or way I can get the radacct table to to move to the next row after midnight ?
That way if a client is connected for weeks, they would have a row for every day, makes it nice and easy !
It’s SQL. You can do anything you want with the data… Think about it
Customer connects (RadAcct gets new row)
Midnight, Active RadAcct data gets copied to different table
Stats run on the different table, not RadAcct… It’s really simple. Just think for a while… No one is going to do your homework for you You have more than enough data in RadAcct to ensure you map propper accounting records (complete or incomplete) with the correct connection in different table…
I know where this guy is coming from…
We had and still have the same problem.
What we do is have all the records for Start, Checkpoint and Stop packets inserted into a MySQL table and run a script on it every 5 min that adds them up and subtracts one row to the next if the client never disconnected.
If he has then we reset the values in our temp table.
But we have a problem, every end of the month we need to reset all the temp values no mater what because hey it’s the end of the month and time for new records right?
But if someone has not disconnected in weeks and we have our temp records reset, when the Router send the new acct values it still has accumulated values from week ago if a client has never disconnected and this makes him look like he downloaded like 10gigs in like 5 min. and thus our script thinks he has gone over his limit and slows him down to turtle speed.
What i have been looking for, for a long time but can’t find it is a RouterOS script that can either disconnect all clients a midnight at the end of each month or reset all the counters on the Router ever so often.
This would be the end of it.
If someone can share this with me I would be glad to share our nifty script that we have worked on for months, it comes complete with STATS time online Uploaded, Downloaded keeps a record for each month so the user can go back and view past history and so on.
