CALEA and Remote Log Server
All of our Mikrotik router use flash drives so there is no place to dump the logs. Since we can specify another server IP, what do we need to run on a Linux or Windows box to store the data?
I’m not sure you can accept this data on remote Linux/Windows server.
what about if you were to get another mikrotik that did use a hard drive and use it for primarily for logging believewireless?
Hardware should even need that much grunt.
Some clarification,
‘ip firewall calea’ provides action,
‘sniff - generates a tzsp stream that can be directed to any Wireshark (Ethereal) server’.
http://wiki.mikrotik.com/wiki/Calea#Intercepting_Packet_Flow
That should be the answer to this question.
what you suggest as Wireshark (Ethereal) server ?
If I am not wrong since Wireshark is only analize tool.
ciao
Max
Any OS, that Wireshark supports,
http://www.wireshark.org/about.html
Using wireshark/ethereal is fine if you just need to capture or search for stuff. However, If you are doing an actual tap for a LEA, they would like it chunked up and hashed, which to my knowledge you can not do with wireshark… and if you could the LEA would not appreciate you looking at there data.
The simplest solution in my case is to create a Virtual machine with routerOS demo license and use that as the server.
-Louis
:smiley: same for me.
thanks
Hi everybody,
In the documentation version 1.5 which applies to v2.9 of RouterOS, at this link: http://www.mikrotik.com/testdocs/ros/2.9/tools/sniffer.php there is a part regarding packet sniffer settings, which says:
Not only Ethernal (> http://www.ethereal.com> ) and Packetyzer (> http://www.packetyzer.com> ) can receive the sniffer’s stream but also MikroTik’s program trafr (> http://www.mikrotik.com/download.html> ) that runs on any IA32 Linux computer and saves received packets libpcap file format.
also
streaming-server (IP address; default: 0.0.0.0) - Tazmen Sniffer Protocol (TZSP) stream receiver
I’ve installed the Wireshark (Ethereal) and I just cand find any option (not even a mention of that option in its help files) to start it as a listening server for incoming TZSP stream.
Has anyone ever tried this in a real life? To start the sniffer at the AP and to establish a stream to the remote server that will log this sniffed traffic?
Any help is more then welcome..
Thanks.
Just install a RouterOS server, on a HD etc. Run a demo license for 24 hours or if you need it more, install a license (not expensive). Then you will have a CALEA server for the future as well. Also, it has been suggested to allow writing this to a secondary, non system drive.
Sorry, but I’m not interested in solving a problem by avoiding to solve it.. Is there any chance to make it work, like it says in the documentation, with the Ethereal?
It is working with Ethereal (it should work), but you have to ensure that correct configuration is used on computer with streaming server. Make sure you have followed this requirements,
  1. configure sniffer to stream to device running wireshark:
    /tool sniffer set streaming-enabled=yes streaming-server=ip.of.wireshark.box
    /tool sniffer start
  2. make sure you accept UDP in wireshark (as TZSP uses UDP to transport data)
  3. if you are streaming wireless sniffer captures (interface wireless
    sniffer), make sure you have newest
    wireshark and newest routeros
  4. you may need to disable WCCP protocol in wireshark (Analyze/Enabled
    Protocols), as that collides with TZSP and by default frames may be
    considered WCCP, not TZSP.
so, all I need to do is start Ethereal (Wireshark), set filters to capture ‘udp only’? And of course to set the analyzer to interpret those udp packets as TZSP packets, to get it all right, is that correct?
(I had got a feeling that some kind of listening server should be started, or something, but if I’m correct, wireshark is only used to intercept those udp packets and that’s it)
I have developed an IDS/IPS system for RouterOS.
It is here : http://sourceforge.net/projects/mt-fw-attack/
You need a linux machine to compile and run it.
It collects syslog messages from your’s routeros device (there are instructions on how to use it) and adds the attackers on an address list which you can use to block them.
:slight_smile:
Sounds cool. How does it work in background. How does it determine that this IP is attacker?
