ttaiw
June 9, 2012, 7:41pm
1
I try to use CALEA to sniff data from interface
and I use Wireshark open pcap files
every first packet in files Arrivl time is jan 1, 1970 ..
any wrong? or Can I settime stamp in package?
and if I using action type limited, what program to open it?
regard,
Dobby
June 29, 2012, 12:34am
3
Deleted because not related.
@ttaiw
When router starts, it take few seconds for NTP client to update system clock.
So first packet is dated Jan 1, 1970.
@Dobby
CALEA is one of RouterOS packages.
http://wiki.mikrotik.com/wiki/Calea
HTH,
Dobby
June 29, 2012, 8:32am
5
ttaiw
June 30, 2012, 4:20pm
6
Thank you for all response.
I was setup with my RB450G and run ROS later version (5.18)
MY Current config
[admin@450g] > ip address print
ADDRESS NETWORK INTERFACE
0 192.168.10.1/24 192.168.10.0 ether2-Lan
1 192.168.30.1/30 192.168.30.0 ether4
2 192.168.31.1/30 192.168.31.0 ether5
3 10.1.1.1/32 10.1.1.1 br_lo
4 D x.x.x.x/32 x.x.x.x Gateway
[admin@450g] /ip firewall calea> print
0 chain=forward action=sniff-pc sniff-target=192.168.10.1 sniff-target-port=5555
sniff-id=100 protocol=tcp out-interface=Gateway dst-port=80,81,443
[admin@450g] > tool calea print
Flags: X - disabled
0 case-id=100 case-name="test" intercept-ip=192.168.10.1 intercept-port=5555
action=pcap pcap-file-stop-interval=1h pcap-file-stop-size=1024
pcap-file-stop-count=0 pcap-file-hash-method=md5
[admin@450g] > system clock print
time: 23:15:17
date: jun/30/2012
time-zone-name: Asia/B..
gmt-offset: +07:00
[admin@450g] > system ntp client print
enabled: yes
mode: unicast
primary-ntp: 203.185.67.115
secondary-ntp: 0.0.0.0
dynamic-servers:
status: synchronized
and I export .dmp files to open with wireshark, Every files frame (Frame1) start time @ 1970-01-01
Can I put time into the package? and if I capture to XML Which program open it?
I have the same problem.
Date is always 1970 under WireShark when load a calea file, and my routerOS clock works fine.
RouterOS 5.26
Some idea??
