Hello all, I’m not sure if my title is descriptive enough.
I want to do this :
local var1 "1st variable"
local var2 "2nd variable"
local varn "nth variable"
local numofvars n
for i from=1 to=$numofvars do={
:put $("var".$i)
Expected output:
1st variable
2nd variable
nth variable
But I’m unable to sucessfully construct varX and call it as a variable.
Is this even possible?
### Initiating the array
:global xxx {1="1st value";2="2nd value";3="3rd value";n="nth value"}
###Getting all values (with the keys) from the array
:foreach key,value in=$xxx do={
:put "Table entry number $key has the value: $value"
###Changing the existing value in the array
:put "Changing 3rd variable"
:set ($xxx->"3") "Different 3rd value :)"
###Reading the specific variable
:local var3 ($xxx->"3")
:put "Variable 3 is: $var3"
###The problem is, that if the value is not already there, to add new value we need to add the existing array to "new" value with concatenation, like:
:put "Adding 5th variable"
:set $xxx ($xxx,{5="5th value"})
###And even more problematic, to add by script, we need to use "execute", like:
:for n from=15 to=19 do={
:put "Setting value $n"
:execute ":set \$xxx (\$xxx,{$n=\"$n-th value\"})"
###But the result is as it should be :D
:local varsize [:len $xxx]
:put "The array now has $varsize elements:"
###And... unfortunately to use :execute we need this array to be global. After running the script we can remove it:
/system script environment remove [/sys script environment find name="xxx"]
I found the way . The part I was missing was - when doing :set ($array->$key) $value - the $key needs to be string, cannot be integer. So now the proper example is as follows:
:local xxx {1="1st value";2="2nd value";3="3rd value";n="nth value"}
###Adding a new value
:set ($xxx->"5") "5th value"
###When adding the value with a script, we need to make sure the array "key" is string, not integer, so - for example:
:local number [:tostr $n]
:set ($xxx->$number) "$n-th value"
###The result is as it should be :D
