Hi;
I have router rb 3011 and point acces 951hd
Point acces get ip of 3011 with 192.168.1.211
In Point acces i have cam wifi in ip 172.17.2.241 and port open in 6300 in firewall Nat
But I dont see cam out side of network of point acces.
In file rules de point acces I make chain forward src 192.168.1.211 to 172.17.2.241 accept.
But dosent work
On the 3011, you need a nat rule that will dst-nat external traffic to your camera’s ip address. This is assuming all your devices can ping each other internally and that you will be using the same port from outside.
It’s not enough to just open the tcp port on the AP.
If you can’t see the camera from a LAN on the 3011, then you need to set since routing for both routers to have full communications. From the 3011, you must be able to ping the camera.
If this it’s not desirable then do dst-nat on the 951 also. Then you should reach the camera from outside the 951 and externally ( if you kept the 1st dst-nat).
