Camera repeater
hello, I hope someone can help, I place for a news Netherlands me an ip camera with an ice rink, because the ice rink in forest standing there is no internet connection.
I want from my house overlooking a flat next to the ice rink a connection to the flat and flat a repeater to the rink.
I was thinking to use as a repeater, with aerials on roof. Linksys access point with DDWRT but it is for example also possible to use, mikrotik SXT g 2Hnd ?
I’m totally new to this product. I was thinking from my house one focused on a flat and flat to 2 and a skating rink? Is that possible? and can for 100 meters. you can focus properly?
Sorry for my bad english.
If you are completely new to the product, then I would suggest having one of your local suppliers help you select the hardware. Many of the suppliers will also pre-configure the link for you and then all you have to do is install it. That will probably be the simplest solution, since MikroTik wireless can get somewhat overwhelming when your new to it.
