can able to downgrade rb2011 to Ros v5.29
I have a router bord 2011. I want to downgrade to Ros v5.29. Is it possible.
And is their any problem if i do downgrade ros.
Thank you.
There is no such version. Maybe this is about 6.29 or 5.26?
RB 2011L - work on 5.26
RB 2011iL - not work on 5.26
Thank you for the last reply. can RB2011UiAS-RM support ros v5.26??
may I ask, what is the reason for downgrade?
Don’t downgrade below the version you got the device with. Of course you can test it and you will see…
Especially DO NOT downgrade any RB2011 to RoS 5.xx! You will get random reboots atleast.
Yeah. We warned you…
RB1100AHx2
RB1100
can this router support ROS 5.X???
Thank you for last reply.
yes, both.
Thank you. Today I’m going to buy this one
help me please .
Last day i buy one RB1100AHx2 Ros V. 6.31
I downgrade the os to v5.26
When the downgrade is complete it’s show the license expires in 24 hrs.
every time i restart the software id is change.
then i again upgrade to Rso v 6.31. It’s working fine.
But again i downgrade the router then the same license problem find.
Please help the on this
Thank you…
Why are you suspect that 5.xx is suitable for RB1100AHx2 ?
Why are you forcing it to use that version ?
I’m also curious why do you need 5.26 on RB1100AHx2? Regarding licence only MT support can help you.
