after i up upgrad RB960PGS to firmware 7.11
The script I used was working but after the upgrad it is not working
I think because the date format changed As shown in the image
2023-08-26 12:35:50 by RouterOS 7.11
software id = 7JS9-I6SJ
model = RB960PGS
serial number = D52F0E49A6C8
add name=bridge1
set [ find default-name=ether1 ] name=ether1-WAN
/interface lte apn
/ip hotspot profile
set [ find default=yes ] hotspot-address=192.168.1.1 login-by=
http-chap,https,http-pap,mac-cookie use-radius=yes
add dns-name=www.a.net hotspot-address=192.168.2.1 html-directory=
flash/hotspot http-cookie-lifetime=4w2d login-by=
cookie,http-chap,https,http-pap,mac-cookie name=hsprof2 use-radius=yes
add dns-name=www.a.net hotspot-address=192.168.3.1 html-directory=
cookie,http-chap,https,http-pap,mac-cookie name=hsprof3 use-radius=yes
add dns-name=www.a.net hotspot-address=192.168.4.1 html-directory=
cookie,http-chap,https,http-pap,mac-cookie name=hsprof4 use-radius=yes
add dns-name=www.a.net hotspot-address=192.168.5.1 html-directory=
cookie,http-chap,https,http-pap,mac-cookie name=hsprof5 use-radius=yes
/ip hotspot user profile
set [ find default=yes ] keepalive-timeout=1m mac-cookie-timeout=4w2d
add idle-timeout=15m !keepalive-timeout mac-cookie-timeout=4w2d name=mumpro
on-login=“{:local date [ /system clock get date ];:if ( [ /ip hotspot user
_get $user comment ] = "" ) do={[ /ip hotspot user set $user comment=
$date];}}” open-status-page=http-login transparent-proxy=yes
add name=dhcp_pool0 ranges=192.168.1.20-192.168.1.254
add name=dhcp_pool1 ranges=192.168.2.2-192.168.2.254
add name=dhcp_pool2 ranges=192.168.3.2-192.168.3.254
add name=dhcp_pool3 ranges=192.168.4.2-192.168.4.254
add name=dhcp_pool4 ranges=192.168.5.2-192.168.5.254
add address-pool=dhcp_pool1 interface=ether2 lease-time=10m name=dhcp1
add address-pool=dhcp_pool2 interface=ether3 lease-time=10m name=dhcp2
add address-pool=dhcp_pool3 interface=ether4 lease-time=10m name=dhcp3
add address-pool=dhcp_pool4 interface=ether5 lease-time=10m name=dhcp4
/ip hotspot
add address-pool=dhcp_pool1 disabled=no interface=ether2 name=hs-ether2
profile=hsprof2
add address-pool=dhcp_pool2 disabled=no interface=ether3 name=hs-ether3
profile=hsprof3
add address-pool=dhcp_pool3 disabled=no interface=ether4 name=hs-ether4
profile=hsprof4
add address-pool=dhcp_pool4 disabled=no interface=ether5 name=hs-ether5
profile=hsprof5
/queue type
add kind=pcq name=“1M uploade” pcq-limit=1000000KiB pcq-rate=1M
pcq-total-limit=1024KiB
add kind=pcq name=“10M download” pcq-limit=10000000KiB pcq-rate=10M
pcq-total-limit=10240KiB
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.2.1/24 interface=ether2 network=192.168.2.0
add address=192.168.3.1/24 interface=ether3 network=192.168.3.0
add address=192.168.4.1/24 interface=ether4 network=192.168.4.0
add address=192.168.5.1/24 interface=ether5 network=192.168.5.0
/ip dhcp-client
add interface=ether1-WAN
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1
add address=192.168.4.0/24 dns-server=192.168.4.1 gateway=192.168.4.1
add address=192.168.5.0/24 dns-server=192.168.5.1 gateway=192.168.5.1
set servers=8.8.8.8
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
add action=masquerade chain=srcnat out-interface=ether1-WAN
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
src-address=192.168.2.0/24
src-address=192.168.3.0/24
src-address=192.168.4.0/24
src-address=192.168.5.0/24
/ip hotspot user
add name=Mar@0556
add comment=2023-07-26 email=5@0_5.ptd limit-uptime=5d name=0557 profile=
mumpro
add comment=aug/10/2023 email=5@0_5.ptd limit-uptime=5d name=055571737
profile=mumpro
add email=5@0_5.ptd limit-uptime=5d name=055337073 profile=mumpro
add email=5@0_5.ptd limit-uptime=5d name=055376002 profile=mumpro
add email=5@0_5.ptd limit-uptime=5d name=055578471 profile=mumpro
add email=5@0_5.ptd limit-uptime=5d name=055174381 profile=mumpro
add email=5@0_5.ptd limit-uptime=5d name=055229176 profile=mumpro
add email=5@0_5.ptd limit-uptime=5d name=055743753 profile=mumpro
add email=10@0_10.ptd limit-uptime=1w3d name=010194993 profile=mumpro
add email=10@0_10.ptd limit-uptime=1w3d name=010486397 profile=mumpro
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api port=8725
set api-ssl port=8726
/radius
add address=192.168.10.2 service=ppp,hotspot
/radius incoming
set accept=yes
/routing bfd configuration
add disabled=no
/system clock
set time-zone-name=Asia/Riyadh
/system note
set show-at-login=no
/system scheduler
add interval=6h name=ex_dis_new on-event=“/system script run ex_dis_user_new”
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-time=startup
add interval=1d name=“system reboor” on-event=“/system reboot” policy=
start-date=2022-10-25 start-time=19:00:00
add interval=1d1h name=expire_users_sched on-event=“{:global today;{:local dat
e [ /system clock get date ];:local montharray ( "jan","feb","mar",
"apr","may","jun","jul","aug","sep","oct","nov","dec" );
:local monthdays ( 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 );:local
_days [ :pick $date 4 6 ];:local monthtxt [ :pick $date 0 3 ];:local ye
ar [ :pick $date 7 11 ];:local months ([ :find $montharray $monthtxt]);
:for nodays from=0 to=$months do={:set days ( $days + [ :pick $monthday
s $nodays ] )};:set days ($days + $year * 365);:set today $days;};:for
each i in [ /ip hotspot user find where disabled=no ] do={:if ([ :find [ /
ip hotspot user get $i comment ] ] = 0 && [ :find [ /ip hotspot user get
$i email ] ] = 0) do={:local date [ /ip hotspot user get $i comment ];:l
ocal oldemail [ /ip hotspot user get $i email ];:local atmark [ :find $o
ldemail "@" ];:local dotmark [ :find $oldemail "." ];:if ( $atmark >
= 0 && $dotmark >= 0 ) do={:local validity [ :pick $oldemail 0 $atmark]
;:local rest [ :pick $oldemail ($atmark + 1) [ :len $oldemail] ];:if (
[:tonum $validity] != "" ) do={:if ( [:tonum $validity] != "0" ) do=
{:local montharray ( "jan","feb","mar","apr","may","jun","jul
","aug","sep","oct","nov","dec" );:local monthdays ( 31, 28, 31
, 30, 31, 30, 31, 31, 30, 31, 30, 31 );:local days [ :pick $date 4 6 ];:l
ocal monthtxt [ :pick $date 0 3 ];:local year [ :pick $date 7 11 ];:loca
l months ( [ :find $montharray $monthtxt ] );:for nodays from=0 to=$mon
ths do={:set days ( $days + [ :pick $monthdays $nodays ] )};:set days (
$days + $year * 365);:if ( ($days + $validity) < $today ) do={ :local
_name [/ip hotspot user get $i name];:log info "HOTSPOT VALITITY EXPIRE
: Disabling Hotspot user $name first logged in $date";[ /ip hotspot use
r disable $i ];[ /ip hotspot active remove [find where user=$user] ];}}}
}}}}” policy=read,write start-date=2022-12-26 start-time=00:04:00
add interval=50m name=ex_dis on-event=“/system script run ex_dis_user”
start-date=2022-12-27 start-time=05:41:30
/system script
add dont-require-permissions=no name=ex_dis_user_new owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="{
:global today;{:local date [ /system clock get date ];:local montharray (
"jan","feb","mar","apr","may","jun","jul","aug","sep","
oct","nov","dec" );:local monthdays ( 31, 28, 31, 30, 31, 30, 31, 31,
_30, 31, 30, 31 );:local days [ :pick $date 4 6 ];:local monthtxt [ :pic
k $date 0 3 ];:local year [ :pick $date 7 11 ];:local months ([ :find $
montharray $monthtxt]);:for nodays from=0 to=$months do={:set days ( $d
ays + [ :pick $monthdays $nodays ] )};:set days ($days + $year * 365);
:set today $days;};:foreach i in [ /ip hotspot user find where disabled=n
o ] do={:if ([ :find [ /ip hotspot user get $i comment ] ] = 0 && [ :find
_[ /ip hotspot user get $i email ] ] = 0) do={:local datee [ /ip hotspot
_user get $i comment ];:local mums [ :pick $datee 0 4 ]; :if ( $mums =
_"mums" ) do={ :local date [ :pick $datee 5 16 ];:local oldemail [ /ip
_hotspot user get $i email ];:local atmark [ :find $oldemail "@" ];:l
ocal dotmark [ :find $oldemail "." ];:if ( $atmark >= 0 && $dotmark >
= 0 ) do={:local validity [ :pick $oldemail 0 $atmark];:local rest [ :pi
ck $oldemail ($atmark + 1) [ :len $oldemail] ];:if ( [:tonum $validity
] != "" ) do={:if ( [:tonum $validity] != "0" ) do={:local montharray
_( "jan","feb","mar","apr","may","jun","jul","aug","sep
","oct","nov","dec" );:local monthdays ( 31, 28, 31, 30, 31, 30, 31
, 31, 30, 31, 30, 31 );:local days [ :pick $date 4 6 ];:local monthtxt [
:pick $date 0 3 ];:local year [ :pick $date 7 11 ];:local months ( [ :fi
nd $montharray $monthtxt ] );:for nodays from=0 to=$months do={:set day
s ( $days + [ :pick $monthdays $nodays ] )};:set days ($days + $year \
- 365);:if ( ($days + $validity) < $today ) do={ :local name [/ip hotsp
ot user get $i name];:log info "HOTSPOT VALITITY EXPIRE: Disabling Hotsp
ot user $name first logged in $date";[ /ip hotspot user disable $i ];}
/tool netwatch
add disabled=no down-script=
“/ip hotspot profile set html-directory=hotspot numbers=3” host=
192.168.4.1 http-codes=“” test-script=“” type=simple up-script=
192.168.3.1 http-codes=“” test-script=“” type=simple up-script=
“/ip hotspot profile set html-directory=hotspot numbers=5” host=
192.168.5.1 http-codes=“” test-script=“” type=simple up-script=
“/ip hotspot profile set html-directory=hotspot numbers=2” host=
192.168.2.1 http-codes=“” test-script=“” type=simple up-script=
Thank you for your help my friends
config.rsc (11.5 KB)
