I have a strange problem with one of the HAP AC’s. It is configured in standard home AP mode (bridge with dhcp-server on eth 2-5 and firewalled eth1 as WAN with dhcp client, masquerading is on outgoing traffic on eth1). This would be a just fine configuration in basics.
Since I need to have this unit available from the outside, I added a firewall rule to allow access to Winbox on port 8291, but strange things happen. I cannot seem to login, yet I can. Once I try to login with winbox (the unit is on LAN right now and I have just put a “allow all from eth1” as the first rule) I can see that the line is struggling with its data transfer (connecting takes time and downloading plugins sometimes hangs). It then finally connects, but all screens in Winbox are empty. For example the interfaces window should always display stuff… after a minute or so, the connection is dropped and winbox closes.
So the port is not being firewalled, but yet cannot seem to stay stable. Connecting using the MAC address instead of the ip doesn’t seem to work at all.
I have already completely reset the configuration and started from scratch - removed all scripts and other firewall rules, but without any luck. If I login from one of the bridged ports (2-5) or via Wifi, I can connect without any problems.
If I can’t get it to work on the LAN I’m sure it won’t work going over internet. What can I do to get this going? Or is the unit faulty?
screenshot: empty windows
screenshot: firewall rules
