Can hap ax2/3 and/or cap ax operate in 5ghz-ac mode (wifi-5)
Is it possible to for hap ax2/3 and/or cap ax operate in 5ghz-ac mode (wifi-5)? As additions to wap AC that are already installed or they can work only as wifi6? ROS 7.13+
802.11an = wifi4 ?
Can’t test right now but normally it should be backwards compatible.
Anyhow, 5ghz-an is in the list of possible bands to be used.
Sorry my mistake :slight_smile: “-ac” ofcource … fixed. “-an” works out of the box … it has separate interface for 2.4 but i dont want to buy 5 devices and then test backward conpatability on 5Hz interface.
The word “band” confuses me a lot. May be I do not undersand the wifi standards, but for me band is not equal to IEEE 802.11ac/IEEE 802.11ax.
Why?
Does it have to be fixed, the standard is backward compatible and will be used by older devices.
Band has to do with radio frequency.
Ac works without any problems.
