Can help me?,L7 KILL .EXE?
3.X version. How to use L7 kill. EXE? Can help me?
Tks!!!
L7 site and can not DORP. EXE
What L7 pattern do you use?
Hint: consult here.
you don’t need to use L7 rules to block exe, you need to use Transparent Webproxy and Access List based on file extensions.
Tks PoniTozheKoni and normis
\x4d\x5a\x90\x03\x04|\x4d\x5a\x50\x02\x04 & \x4d\x5a(\x90\x03|\x50\x02)\x04
All, Can not stop .EXE download.
Webproxy Dorp .exe is OK.
But,I still like to direct, not through Webproxy.
This high efficiency.
Thanks again for.
Try this:
No # and space after #.
Some sites contains .exe as a part of URL.
Thank you, Mr.Hope sit
that you have given me the correct answer. You are the world’s first find the exe of the L7, and as a mark.
