Hi..
My a question, can hotspot users connect to emule with high id? i try with this rule :
add chain=dstnat protocol=TCP dst-port=4662 dst-address=PUBLICIP action=dst-nat to-addresses=10.0.0.0/24 to-dst-port=4662
add chain=dstnat protocol=UDP dst-port=4672 dst-address=PUBLICIP action=dst-nat to-addresses=10.0.0.0/24 to-dst-port=4672
but not work!!
Any ideal…
Thanks and regards!
Mikro-Man-Tik:
Hi..
but not work!!
Any ideal…
Thanks and regards!
Use netmap if youre using NAT
First,.. thanx cibernet for your Reply..
so I am trying to use netmap like:
add chain=dstnat protocol=TCP dst-port=4662 dst-address=PUBLICIP action=netmap to-addresses=10.0.0.0/24 to-dst-port=4662
add chain=dstnat protocol=UDP dst-port=4672 dst-address=PUBLICIP action=netmap to-addresses=10.0.0.0/24 to-dst-port=4672
But not work and there is no one packet in firewall nat rule statistics?!.
Is there any good way or someone have idea to that?
MT 2.9.10
thanks and regards!
Mikro-Man-Tik:
MT 2.9.10
thanks and regards!
You cant bind one public port to the entire LAN… you cand do 1:1 NAT
Example port 999 external to internal 4662… the user must change the port on emule…
Regards
