Can I change routes cost between two routers? How?
Please, consider the following scenario; all points are routers running ospf in the same area:
  • Both routers A and E are borders; As you can see, OSPF will make router D have two gateways (routers C and E). Router A is redistributing default route as type 1. How can I change (increase) default route cost between router F and E to move the two gateways from router D to E? I mean, in this scenario I want router E to have two gateways only, via ospf using MT ROS 3.23. Please, help?
