Can I connect PSU + POE at the same time, ccr1009?
PSU 220v
POE 27,8v
Check this old post out.
Yes. I accidentally did this on some kit I’m testing some stuff on.
Thank you very much for the answers. I sent e-mail to mikrotik support, and they replied:
please,
Can I power on ccr1009
in ac 220v together POE 27.8v? my batteries are POE.
I’m afraid to connect the two together.
Yes, you can, many people use such a setup for redundancy.
Internally the PCB works at 24V and will choose the voltage that is higher, in your case priority will be on the PoE input.
Best regards,
Arturs Z.
