like I disable ether1 or LTE1?
Thanks ,
Thanks ,
Hi David
Firstly you have to confirm your USB device number using this command in new terminal
system resource usb print
this will show the list of your usb device if you have any
than you can disable the USB by the device number
o.k.
But I can’t disable it
there isn’t any disable\enable there
Thanks ,
