Can I enable CAPS on a Groove 5Hn?
Hi folks,
I have a Groove 5Hn that I was wanting to use in an existing CAPS network (cloudcore router running CAPSman, and a couple of CAPac APs). I tried holding the reset button for 10 seconds, but the led did not cycle through the correct pattern to indicate that it had entered CAPS mode. I know the Groove series can do CAPS, but I suspect that I’ve hit a limitation on the 5Hn specifically as I see from the advertising material that the 5Hn only comes with an L3 license, and I gather you need L4 or higher to enable CAPS.
I do own a L4 license key that I haven’t used yet - would applying that to my Groove cause it to all magically work or would I just be wasting the license?
