Can i have two sstp-server running at the same time with 2 diferent certificates?
I have used hEX Mikrotik as SSTP VPN concentrator with one ISP and one certificate asociated to ISP public ip.
Now i added a second ISP with a new certificate.
but i have consused with this, i think this replace the oder certificate
/interface sstp-server set certificate=newCertificate bla bla bla
Thanks!
Sorry, not, only one SERVER at time, but multiple CLIENT… understand? :wink:
thanks rextended, yes I understand!
and you known if can make a certificate with two ips?
for example i create the certificates with this commmand
/certificate add name=mycertificate country=ar state="Buenos Aires" locality=CABA organization="Hogar 2.0" unit=IT common-name=ispA_IP key-size=2048 days-valid=3650 key-usage=key-cert-sign,crl-sign
/certificate sign mycertificate ca-crl-host=ispA_IP name=myCA
how can i create the certificate for support two ips, for example ispA_ip and ispB_ip?
ssssssst! it’s a secret :))
subject-alt-name=IP:1.23.3.5,IP:1.63.4.2
ok, I will try
/certificate add name=mycertificate country=ar state="Buenos Aires" locality=CABA organization="Hogar 2.0" unit=IT subject-alt-name=IP:1.23.3.5,IP:1.63.4.2 key-size=2048 days-valid=3650 key-usage=key-cert-sign,crl-sign
I’ll by back
