Can I Install ROuterOS 3.2x ??
Hello
Can I Install ROuterOS 3.2x ?? on
Acer DualCore 2GHz CPU - 1GB DDR RAM - 160GB SATA HDD
Pls.. i boots frm USB-CD rom .. It boots but When Looks for Harddrive…
There comes Fatal Error.. No HardDrive Found..
HELP Me.
Reply to me on
GujaratiKanudo@GMail.com if Possible..
Thank You In Advance…
..MEHUL
you should install v4.10 or better - v5beta4 because it has more drivers for X86 and supports multicore much better.
thanks normis..
ive tried 4.10 too.. but still that prob…
“No harddrive found”
well i will try 5.x now… i hop i can do next..
thankx..
if v5 doesn’t find the drive too, experiment with the BIOS settings. Try different AHCI modes for the drive.
