Can I load a script when I'm using NetInstall?
is it possible to run a script\startup config of my own when I run the Netinstall ?
Thanks,
See: http://wiki.mikrotik.com/wiki/Netinstall The “Configure script” option lets you customize the script that is run when you reset the router to it’s “default” configuration.
This page has information on the standard ones for each router model/family, including how to get the standard one from the router itself. http://wiki.mikrotik.com/wiki/Manual:Default_Configurations
Thanks!
