I want to save the data on my disc in Windows for study, the same data than we can look in Tools/Graphing/Queue Graphs
can i do this?
Thank you.
can i do this?
Thank you.
you can use Cacti for example, to do this:
http://forum.mikrotik.com/t/cacti-mikrotik-routeros-statistics-update-11-19-2013/18506/1
Thanks for your quick reply, greetings, we met in Argentina MUM.
I had already thought about that option.
I wanted to extract the data directly from Mikrotik, accessing the directory “/var/www/mrtg/data/queue1” or similar.
using a script that transfers this data to /Files.
Is it possible?
Thank you.
Maybe a script that can e-mail you a file from the file system? Limited to certain files like this one. Looks like a feature request.
no that won’t happen
Setup a separate Cacti server. Really, bite the bullet and you’ll be happy.
I’m setup a Cacti server, it’s wonderfull, but when I change any record of my Simple Queue is difficult to do in the Cacti
It would be very simple to copy information from directories Mikrotik, it could make mounting the ROS disk in a Linux and read their directories?
I’ve been graphing my mtks for ages using those scripts. It truely is a greAt tool. Take a look at factoRS at cactiusers.org. It is a self installing version that has most of the common plugins installed. If you hit my blog I have some getting started tutorials for cactiez.
