Can i set my r5h card tx-power to 25?
I want to set my r5h card tx-power to 25. Will it do harm? I have to boost it a little b’cos there are some high trees in the way and the wind is also a issue. I dont want to damage my r5h card.
lol i have check that when my tx-power is set to default then it is 25.
Womder what will happen if i set it to 30.
What is the highest safest tx-power setting that i can use on the r5h
not more than default, unless you intentionally want to burn it. this setting is for lowering power
Thanx i think i going to leave it default
