Hello.
For educational purposes I have bought a second-hand RB532 (the note on the board says, that it is v5). I’m tying to update its system as high as possible. I have ound in the Iinternet, that even the latest versions should work. Unfortunatelly…
My system now says:
[admin@RB532] > /system license print
software-id: "I66H-34V9"
upgradable-to: v3.x
nlevel: 4
features:
I have managed to find ROS 4.0rc1 and it was installed and seems to work. But I cannot get any higher. OK, the note above clearly says, that “upgradable-to: v3.x”. But is it possible to somehow make it higher? Maybe it is possible to, for instance, buy a new license (for a reasonable pice, which now should be close to 0 to be reasonable, but…)? Or anything other than buying brand new router?
