can i upgrade to routeros5.0 beta6 in my RB433AH
I am running RB433AH with routeros 4.11 can i upgrade it to routerboard 5 beta 6 it is upgradable up to v6.x because i am not sure as it is still under beta only that’s why i am not confident to do so.
please advice
Birender
You can upgrade to ROS 5.0b6. I have that exact unit running that software load.
I thought I read somewhere that beta versions are not affected by the ‘upgradable-to’ field in /system license. Meaning, you could upgrade to 5.x beta even if upgradable-to only says 4.x. I can’t seem to find any info on this, so I may just be crazy.
