I am using a RB951G-2HnD router and it’s currently running v5.26. Clicking on Check for Updates tells me that 5.26 is the latest version.
However, I see posts that (I think) I should be able to upgrade to v6.7 such as the following gentleman using the same RB951G-2HnD router:
http://forum.mikrotik.com/t/rb951g-2hnd-relatively-low-speeds-on-lan-wlan/73170/1
I have tried to follow the upgrade steps advised in the following manual, though when I try to drag and drop the routeros-mipsbe-6.7.npk file in the Files List in Winbox, it does not allow me to drop the file.
What am I doing wrong?
Thank you very much for your advice!
Dundy
