Hi
Can it be better then this?
I am running a 411ah whit R5Hn and jirous duplex antenna. The distance is about 1.9km.
The HT40-5,6,7 danced up and down between 11 and -70 when running bandwidth test.
Is their anything that I can do to increase the speed a little?
On the AP-Site
# nov/24/2011 16:00:41 by RouterOS 5.9
# software id = TMDQ-Q9NA
set default authentication-types=wpa2-psk,wpa2-eap eap-methods=passthrough \
group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
management-protection=disabled management-protection-key="" mode=\
dynamic-keys name=default radius-eap-accounting=no radius-mac-accounting=no \
radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=\
XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none \
static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" \
static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=\
none static-sta-private-key="" static-transmit-key=key-0 \
supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates \
unicast-ciphers=aes-ccm wpa-pre-shared-key="" wpa2-pre-shared-key=********
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area="" \
arp=enabled band=5ghz-onlyn basic-rates-a/g="" basic-rates-b="" \
bridge-mode=enabled channel-width=20/40mhz-ht-above compression=no country=\
no_country_set default-ap-tx-limit=0 default-authentication=yes \
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
disable-running-check=no disabled=no disconnect-timeout=3s distance=dynamic \
frame-lifetime=0 frequency=5320 frequency-mode=manual-txpower \
frequency-offset=0 hide-ssid=yes ht-ampdu-priorities=0,1 ht-amsdu-limit=\
8192 ht-amsdu-threshold=8192 ht-basic-mcs=mcs-14,mcs-15 ht-guard-interval=\
long ht-rxchains=0,1 ht-supported-mcs=\
mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23 \
ht-txchains=0,1 hw-fragmentation-threshold=disabled hw-protection-mode=none \
hw-protection-threshold=0 hw-retries=15 l2mtu=2290 mac-address=\
*************** max-station-count=2007 mode=bridge mtu=1500 name=wlan1 \
noise-floor-threshold=default nv2-cell-radius=20 nv2-noise-floor-offset=\
default nv2-preshared-key=****** nv2-qos=default nv2-queue-count=2 \
nv2-security=enabled on-fail-retry-time=100ms periodic-calibration=default \
periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=\
post-2.9.25 radio-name=********* rate-selection=advanced rate-set=\
default scan-list=default security-profile=default ssid=******* \
station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g="" \
supported-rates-b="" tdma-period-size=2 tx-power-mode=default \
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=\
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
wireless-protocol=nv2 wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbp\
s:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:17,H\
T20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,HT40-0:\
17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
3200 framer-policy=none
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no \
streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
