I assume you want to make VPLS tunnel over the internet? If so then it is not a good idea, because directly it will not work, VPLS works only over MPLS cloud.
So you will need to create L2 tunnel between two routers (Like EoIP), then run LDP or other label reservation protocol over that tunnel and only then you will be able to run VPLS tunnel.
