Hello sorry about my english i hope you understand me.
My problem is that i cant get contact to my router is a RB1100AHx4 Dude Edition i have try every thing. Hope you can help me cheers all
Reset it and use default login admin with blank password.
Assuming you have a backup the reset and restore will be very quick.
Before resetting, let us know which ways have you tried to login?there is an error in user/password? Does is say “connection” but nothing happens? have you tried with ip or MAC? Have you tried Winbox or web interface?
Hello Miktotik team.
Kindly assist me also.
To connect to web config on mikrotik routerboard I need the ip address of my routerboard but the problem is that I don’t know the ip address of my routerboard. Is there anyway I can get the ip address of my routerboard in other to connect to the webfig?
Best regards
Download and install WInbox, this will give you the ability to search the L2 for your MikroTik device and if it has an IP assigned show you what it is. Winbox will also allow you to manage the device much more smoothly then webfig.
