can MK do these three thing !
Hi all
Several issues going on in my head
NO 1 :
I have RB1000 main router… and i have many point RB411A &RB433AH … i want to see the domain name that i see it in access ! i want to see it in the main router … can i see my client domain !
NO 2 :
all my network return to RB1000.. am using usermanger… i want to make every access like 433AH router and give the clients ip and getaway different .. every point has another ip another getaway… put all of these at the end return to RB1000 … can i do this !
NO3 :
if the answer for NO2 yes … can i install hotspot for every point PUT all the name and password gives from RB1000 …can that happened ???
Proposal, opinion, insights, help are welcome
sorry for Best E in all over the world : )
up
I don’t understand the question.
If you mean can different user managers share the same database, the answer is yes. You may want to look at a RADIUS based solution though.
If by this you mean - “can you have access to the clients domain back at your RB1000 at Layer2” - then Yes
How are your RB411/433’s etc connecting back - is it via wireless, ethernet, ADSL ??
again not sure I understand the question, but here goes.
If you are wanting each client to connect back to the RB1000 on its “own” network, then yes - just allocate a /30 network between client RB433 and RB1000
