Hello everyone,
What am I doing wrong here?
I have testing environment setup in the shop. I have the MT card with 4 interface installed in the MT box. one of the interface is setup as local with 10.1.0.1/24 for the gateway. The second interface is setup as a hotspot with 10.1.1.1/24 as the gateway. The problem I have is, when I’m using the hotspot interface I can not use winbox or telnet to access the router. I can ping the local interface from the hotspot interface. On the local interface I can access the router thru the winbox and telnet. On both interfaces I can acess the internet fine. I have added a firewall rule input in the router to allow access from both networks. The aloow rule comes B4 the drop rule. I am running ver 2.8.27.
The second question I have is if I bridge both the local and hotspot interfaces and use one AP, will clients who are setup to use the local or hotspot be able to access the network thru one AP?
THX
Ben
