kr33
October 6, 2012, 7:40pm
1
Hi All,
The ppp client is connected but I can’t browse the internet via the LAN or WLAN, How do I get this to work, even the hotspot tutorial doesn’t help.
If i remove the default configuration after i reset, then the Router in inaccessible.
Any help would be highly appreciated
Thanks in advance
jadu
October 8, 2012, 1:35pm
2
Did you make masquerade on ppp interface?
kr33
October 8, 2012, 5:26pm
3
I’ve tried that, but not sure if i’m doing it right.
Do I go to IP->Firewall->NAT?
Forgive the questions…this is my first RouterBoard
jadu
October 9, 2012, 6:20am
4
Yes in IP → Firewall → NAT
Masquerade - srcnat - ppp-out1 or what else you have named your ppp interface.
Have you tried to ping an external IP from the router?
Is the ppp connection established?
kr33
October 9, 2012, 6:52am
5
If I ping a site (using the ip) from the router, i get replies. Even when I set masquerading for the PPP interface. Still nothing via the PC/WLAN
Even if i click manual in Winbox, i get the page cannot be displayed message
jadu
October 9, 2012, 7:21am
6
If you ping from PC an external IP, not address is it responding?
Set allow-remote-requests: yes in IP → DNS
Try to share your ip->routes.
kr33
October 9, 2012, 7:55am
7
Thanks, will try that and let you know
kr33
October 9, 2012, 7:31pm
8
I got it working!
Turns out that aside from doing what you advised me to do, i had to have “Use Peer DNS” checked in my case, i had it unchecked all the time and it never worked.
Thanks a mil
