I used gns3 dan chr, when I used dhcp server, I can not ping to outside (google.com, yahoo.com etc) but when I not used dhcp server, I can ping to outside.
Is it normal or something wrong with my setting ?
The network settings in dhcp server it’s correct?
In the past I had a similar issue and I’ve solved correcting the value in network tab.
Sent from my MI 5s using Tapatalk
I using same IP but one not used dhcp server and another again using dhcp server, but I will try again to make sure
But my word are about gateway and dns settings not about IP.
yes..you’re correct, I am forget gateway. thank you so much
[emoji6]
