I have problem.
I have RB2011L-RM, MIkrotik version 6.15, all run is ok, BUT sometimes i can’t connect remotely via SSH or Winbox, wherein it works: forwarding ports, filters firewall, NAT etc.
Access is restored after a reboot(off/on power).
All services are installed in the router work.
Forwarding port (dst-nat on different port) - i can connect to inside servers.
I have response on ping its ip-address.
But when i try to connect from the outside to the router via ssh or winbox nothing happens.
SSH - timeout connection
winbox - simple wait
After reboot power(off/on) i can connect to the router.
Maybe your UDP/53 port is open and you’re getting queries from outside your network. Put some firewall rules or disable the service completely if you’re using an external DNS server for that network.
