Hi all,
Recently I bought a RouterBOARD 951G-2HnD device, and now trying to connect to my Internet provider via PPTP.
The problem is that the connection seems established, but after short period of time is terminated with the following message in the log: “failed to authenticate ourselves to peer”. The credentials are double-checked, and my old D-Link DIR-615 is able to connect using the same credentials.
Can anyone please help me?
This is my PPTP configuration:
Below is the debug log for the PPTP connection:
# Time Buffer Topics Message
649 Mar/29/2015 13:18:35 memory pptp, ppp, info SELS_PPTP: initializing...
650 Mar/29/2015 13:18:35 memory pptp, ppp, info PPTP->: SELS_PPTP: initializing...
651 Mar/29/2015 13:18:35 memory pptp, ppp, info SELS_PPTP: connecting...
652 Mar/29/2015 13:18:35 memory pptp, ppp, info PPTP->: SELS_PPTP: connecting...
653 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: sent Start-Control-Connection-Request to 83.172.32.6
654 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: protocol-version=0x0100
655 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: framing-capabilities=2
656 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: bearer-capabilities=0
657 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: maximum-channels=0
658 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: firmware-revision=1
659 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: host-name=MikroTik
660 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: vendor-name=MikroTik
661 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: rcvd Start-Control-Connection-Reply from 83.172.32.6
662 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: protocol-version=0x0100
663 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: result-code=1
664 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: error-code=0
665 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: framing-capabilities=3
666 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: bearer-capabilities=3
667 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: maximum-channels=0
668 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: firmware-revision=4608
669 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: host-name=7201Sels
670 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: vendor-name=Cisco Systems, Inc.
671 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: sent Outgoing-Call-Request to 83.172.32.6
672 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: call-id=0
673 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: call-serial-number=0
674 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: minimum-bps=2400
675 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: maximum-bps=10000000
676 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: bearer-type=3
677 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: framing-type=2
678 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: packet-recv-window-size=100
679 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: packet-processing-delay=0
680 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: phone-number-length=0
681 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: phone-number=
682 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: subaddress=
683 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: rcvd Outgoing-Call-Reply from 83.172.32.6
684 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: call-id=33873
685 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: peers-call-id=0
686 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: result-code=1
687 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: error-code=0
688 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: cause-code=0
689 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: connect-speed=64000
690 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: packet-recv-window-size=16
691 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: packet-processing-delay=0
692 Mar/29/2015 13:18:35 memory pptp, debug, packet PPTP->: physical-channel-id=0
693 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP lowerup
694 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent LCP ConfReq id=0xc
695 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <mru 1450>
696 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <magic 0x3985b203>
697 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <mrru 1600>
698 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP open
699 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: rcvd LCP ConfReq id=0x1
700 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <magic 0xc1520d91>
701 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <auth pap>
702 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent LCP ConfAck id=0x1
703 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <magic 0xc1520d91>
704 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <auth pap>
705 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: rcvd LCP ConfRej id=0xc
706 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <mrru 1600>
707 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent LCP ConfReq id=0xd
708 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <mru 1450>
709 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <magic 0x3985b203>
710 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: rcvd LCP ConfNak id=0xd
711 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <mru 1500>
712 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent LCP ConfReq id=0xe
713 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <magic 0x3985b203>
714 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: rcvd LCP ConfAck id=0xe
715 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <magic 0x3985b203>
716 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP opened
717 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent PAP AuthReq id=0x4
718 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <user XXX>
719 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: <password XXXXXXX>
720 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: rcvd PAP AuthNak id=0x4
721 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: Request Denied
722 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP close
723 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP closed
724 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent LCP TermReq id=0xf
725 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: failed to authenticate ourselves to peer
726 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: rcvd LCP TermReq id=0x2
727 Mar/29/2015 13:18:35 memory pptp, ppp, debug, packet PPTP->: SELS_PPTP: sent LCP TermAck id=0x2
728 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP lowerdown
729 Mar/29/2015 13:18:35 memory pptp, ppp, info SELS_PPTP: terminating... - failed to authenticate ourselves to peer
730 Mar/29/2015 13:18:35 memory pptp, ppp, info PPTP->: SELS_PPTP: terminating... - failed to authenticate ourselves to peer
731 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP lowerdown
732 Mar/29/2015 13:18:35 memory pptp, ppp, debug PPTP->: SELS_PPTP: LCP down event in starting state
733 Mar/29/2015 13:18:35 memory pptp, ppp, info SELS_PPTP: disconnected
