Can not connect via Winbox
Hi All
Can some one assist me here.I have a RB433 ,two vsat links are connected to port 1&2.problem is I can not connect to the Port 1 via winbox but I can ping it fine. I can connect to the second
port via winbox.there is not any firewall rule to deny winbox packets on port 1,also for a test
i disabled all firewall rules but problem didn’t solve and i see this error message :" Could not connect to x.x.x.x:80-no response!" when trying to connect winbox using port 1 public ip address.
Most likely router is responding over port2. You have to properly set up policy routing so that packets belonging to the same connection is routed over the same port.
